Tool Talk Discussion Forum
Tire Load Cart
Steve-Maine
12-21-2004 12:36:30
I am looking for a chart that will tell amount of weight a certain tire will hold and also what width of wheel to use with each tire. Thanks in advance
Bob
12-21-2004 15:44:38
 Re: Tire Load Cart in reply to Steve-Maine, 12-21-2004 12:36:30
You don't specify AG or truck or passenger.
Here's AG:
Link
Here's one for trucks:
Link
Steve-Maine
12-21-2004 17:52:44
 Re: Tire Load Cart in reply to Bob, 12-21-2004 15:44:38
I'm trying to find a 6 hole wheel 15 or 16" which will handle about same load as a 9.50x16.5 tires. I got a quote of $95 for 16.5 wheels which I think are high.
CNKS
12-22-2004 07:31:25
 Re: Tire Load Cart in reply to Steve-Maine, 12-21-2004 17:52:44
If you are talking steel wheels, you should be ok. If you mean aluminum, look for a stamped number, likely inside the rim. You may find the wheels rated lower than the tire, as is the case on my GMC pickup with OEM aluminum wheels.
RJ-AZ
12-21-2004 20:00:10
I replaced my 8 hole 3/4 ton wheels with LT285/75R16 on regular 16" steel wheels.
