Tool Talk Discussion Forum
winches
ric
12-19-2004 10:54:07
hi i need a winch to pull trees about an average of 14 to 18 inches in diameter out of a small ravine about 30 ft deep for firewood use and just general cleaning up. should i go with a pto type or a 12volt type ill be using a massey ferguson 35 diesel any input will be app.thanks RICK
Leland
12-19-2004 22:21:34
 Re: winches in reply to ric, 12-19-2004 10:54:07
Look in truck salvage yards plenty of electric trucks that have seen there better days and you should be able to find a decent pto winch there.
thurlow
12-19-2004 16:16:45
This is not what you asked (and I don't know how experienced you are), but personally I would just buck 'em into whatever length the tractor would handle and pull 'em out..... ...
T_Bone
12-20-2004 03:41:36
 Re: winches in reply to thurlow, 12-19-2004 16:16:45
Hi ric,
I'm with thurlow. Use some 3/8" wire rope and a snatch block and pull them out with the tractor.
If you want to lift the logs onto a trailer, use a tri-pod made from 3 logs with another snatch block.
T_Bone
NC Wayne
12-19-2004 16:03:37
For what your gonna be doing with it I'd go with the PTO powered winch. That way you can use the winch constantly without any major problems. If you wanted to go with the electric driven one you'd have to give your charging system a major upgrade, probably add an extra battery, etc and you'd probably still not get even close to having the consistent power to do what the PTO would give.
ric
12-19-2004 17:52:10
 Re: winches in reply to NC Wayne, 12-19-2004 16:03:37
thanks guys
