Tool Talk Discussion Forum
88 F150 Tailights / Instument Cluster light fus
peter kosloski
12-17-2004 07:04:19
I have an 88 f150 and it has developed a nasty appetite for fuses in slot (4). The fuse blow imediately I rang all the wires back to the lights all seem and look ok. Any body had a light switch do this or the cluster lamp ? Any help appreciated this is my #1 runner and it is a pain driving only in the day.
peter kosloski
12-17-2004 13:00:08
 Re: 88 F150 Tailights / Instument Cluster light in reply to peter kosloski, 12-17-2004 07:04:19
Thanks for the ideas Just found what it was. Looking at it during lunch the fuse it put in di not blow until I slammed the hood shut. It was old wires from some fog lamps (previous owner) had just clipped, one wire pinched in front body mount. The resetable fuse is a great idea.
BB
12-17-2004 10:00:33
Remember that the continuity can check out OK but they could still be shorted to ground. Did you check each wire for a short to ground? With the lamps in, there should be some small resistance measured to ground. With the lamps removed, there should be a really high resistance.
Bob
12-17-2004 07:12:19
The system is set up so that when a short in the taillight circuit occurs, it blows the fuse it shares with the instrument light cicuit, to let you know there is a problem (tail lights out).
You need to troubleshoot the taillight wiring and bulb sockets to find the short.
Not quite sure what you mean bye "rang" the wires to the taillights, though???
peter kosloski
12-17-2004 07:46:41
 Re: 88 F150 Tailights / Instument Cluster light in reply to Bob, 12-17-2004 07:12:19
Sorry "rang" is slang for continuity test of wires and they checked out fine.
Bob
12-17-2004 10:17:12
 Re: 88 F150 Tailights / Instument Cluster light in reply to peter kosloski, 12-17-2004 07:46:41
Take a close look for damaged insulation on the taillight wires where they are exposed to road debris thrown by the rear tires, and check the wiring to the license plate lamps (if any remain).
If a trailer wiring plug has been added suspect it and all wiring from the original harness to the trailer socket.
At an auto supply store you short be able to find an auto-resetting circuit breaker that will plug in in place of the fuse. (Match the amperage.)
With the breaker in place you can crawl around under the truck and wiggle wires until the breaker trips, helping to narrow down the problem. If you do that in a darkened area, you may even be able to see a spark where the short is under the vehicle.
I have a 1984 Suburban with beat-up taillight wiring that would occasionally blow the fuse. About 2 months ago, I replaced the fuse with a breaker, and taped things up a bit behind the LH rear wheel, and so far the breaker hasn't tripped.
The breaker is kinda nice because if it does trip at night, it will reset when the lights are shut off, and it saves having to rummage around under the dash to replace a fuse while on the road!
