Tool Talk Discussion Forum
windows
Glen 2
12-16-2004 15:16:32
I bought my grandson a car the other day that has the very dark film on the windows. What is the best way of taking this off short of changing out the glass? I'm sure some of you fellows have a solution for this. Thanks
Sandy11
12-18-2004 05:28:48
 Re: windows in reply to Glen 2, 12-16-2004 15:16:32
Byfar the best way of taking it off is the same way it was put on. Use a heat gun set at low temp. Start at one corner and start pulling, you will be suprised how easy it is to remove and will not scratch your glass.
Glen2
12-17-2004 09:06:20
I went out this morning the temp. was about 28F and took a razor blade scraper started the edge made scoring about every two inches got it started and it peeled right off. The side away from the sun peeled easier than the one with the sun shining on it. It will peel easer cold than when warm. Now getting the glue off may be a different story. When the kids were showing cattle we used glue on some of the hair and used WD40 to get it off I might try that. Thanks for all the info. Glen
greenbeanman
12-17-2004 06:46:17
I don't know how to take it off, but I applaud you for seeing that it is done.
Davis In SC
12-16-2004 19:04:29
Two products that might work are "OOPS" or "GOOF-OFF" Both work well for me, to get stickers off of things. They can be found in most paint departments.
RZ(WA)
12-19-2004 12:42:08
 Re: windows in reply to Davis In SC, 12-16-2004 19:04:29
Xylene is the main component in OOPS and Goof-Off and is far less expensive than either. Whether you use xylene or either of the consumer 'Goof-Off' type products, do a test patch to see if it will melt any plastic or other nearby surfaces. If any of them do, use lighter fluid or kerosene to remove the glue residue. Lacquer thinner may work also, and be less flammable.
bo
12-16-2004 18:02:53
google it. "removing window tint film"....heat, ammonia/dish soap and time. Do a search...
Tom in TN
12-16-2004 17:30:03
Glen,
I've never tried the stuff and I don't know what it's made of, but I've seen some stuff specifically designed for removing the tinting film right next to the film itself in the stores where I've seen it sold
I know that my local Home Depot sells the film and the removal kit.
Good luck,
Tom in TN
RustyFarmall
12-16-2004 17:03:45
I personally have never tried to remove it but I think the only way is with a razor edged scraper.
Jerry CEnt. Mi.
12-16-2004 17:12:14
 Re: windows in reply to RustyFarmall, 12-16-2004 17:03:45
Use a single edge razor blade and cut to the glass in 1/4 to 1/2 inch strips and peel them from the glass.
