Tool Talk Discussion Forum
Winch electrical hookup
Ryan-WI
12-15-2004 16:40:48
I am finally getting around to wiring my winch in so that I can use it on my trailer and my truck. I have everythign I need but I was thinking that I saw someone post about a type of connector that they use. I thought it was from a marine application. I want to put quick disconnects on it so that I can keep the majority of the wiring (I got a wireless control for it) in my trailer toolbox and just connect the leads for the winch. Problem is that the disconnects they sell for winches won't really mount well. I was hoping for something more like the shape and design of a trailer plug. But in 2 wires of a large gauge. Anybody know anything like that?
Bernie in MA
12-16-2004 16:23:38
 Re: Winch electrical hookup in reply to Ryan-WI, 12-15-2004 16:40:48
Maybe you could use welding cable twist connectors.
don12
12-16-2004 05:45:02
electric lift truck battery connectors work very well
Ryan-WI
12-16-2004 04:22:19
I did some searching on another forum last night and someone brought up the idea of using a trolling motor socket. Anyone have any experience with this? It will take 6 gauge wire so I figure it should work ok.
Rod in Smiths Falls, ON,
12-16-2004 14:48:33
 Re: Winch electrical hookup in reply to Ryan-WI, 12-16-2004 04:22:19
I wouldn't think a trolling motor socket would be heavy enough for anything but a trolling motor.
My 36 lb. Motor Guide troller will run all day on a small, 12v deep cycle battery, so the current draw just isn't very high.
For a winch I'd look to the kind of wiring and connections that serve a starter motor.
Ryan-WI
12-16-2004 15:58:38
 Re: Winch electrical hookup in reply to Rod in Smiths Falls, ON, , 12-16-2004 14:48:33
Rod, the one I found takes six gauge wire. The way I figure my line drop that is what I should need to run all the way from my truck to the rear bumper. This plug won;t actually be more than 4 feet of the factory wire and the factory wiring harness is only 8 gauge.
Big Jim
12-15-2004 23:42:05
If you are familiar with the Berg plug that is used for connecting semi-trailer lights, check out the single pin version. For hot and ground, you might want two. I've used them to supply power to an electric lift gate on a van body trailer.
Leland
12-15-2004 22:13:34
Find some lugs like they use to hook up jumper cables on the front of tow trucks,there heavy enough.
Johnbob
12-16-2004 17:19:54
 Re: Winch electrical hookup in reply to Leland, 12-15-2004 22:13:34
I use welding cable connectors.Also I put the winch in front of the truck bed,that way I can drop the tailgate and use it for trailers and truck.No need for extra battery
