Tool Talk Discussion Forum
Cummins fan shroud
Rob Mo.
12-15-2004 09:01:13
Does anyone where a fan shroud for my 90" Dodge pick-up might be found? Hard to find them around here, seem it is not a dealer item & none of the local junkyard carry them. Any info would be grateful.
Leland
12-15-2004 22:15:23
 Re: Cummins fan shroud in reply to Rob Mo., 12-15-2004 09:01:13
Try 1-800-4parts4 they ship UPS nothing but trucks parts from 1/2 ton and up.
caseyc
12-15-2004 15:00:39
well i have a call into some reliable sources right now. i'll try to have an answer thursday sometime if you don't get one sooner. i work for a dodge dealer and it is obsolete from dodge. part number 4428173 for $30.60 if it was still available. i'll let you know.
casey in SD
TSGT TODD HAZUGA
03-16-2005 14:30:58
 Re: Cummins fan shroud in reply to caseyc, 12-15-2004 15:00:39
I came across your discussion of the Cummins fan shroud and was wondering if a good source was found for this item. I work for the Air Force in the Vehicle Maintenance material control section at Misawa AB Japan. I've tried sourcing through dealers/aftermarket sources and junkyards--No luck. Any help you could provide would be greatly appreciated.
the tractor vet
12-16-2004 05:23:18
I just love the way Chrysler does with parts , i have a 95 Dodge 3500 Cummins and needed the fuel lies from the tank to the fire wall they don't have them ya can't them and when i call the 1-800- I don't give a shut i was told by the person that it is and old truck and i should just junk it and get a new one.How things have changed since i was a mechanic and parts manager for Chrysler If you are going to make this junk with stuff that ya can't get down the road when ya need it then why should we pay the price that they want for the junk that they sell if it only going to last till the 3 and 36 is gone . Before ya get it paid for you are having trouble getting parts to fix it.
caseyc
12-16-2004 05:51:39
 Re: Cummins fan shroud in reply to the tractor vet, 12-16-2004 05:23:18
i did some looking and everything i find is still available. i need to know what the wheel base is, 3/8 or 5/16 line/hose, club cab or reg and do you need all the lines or just a supply, or a return? from the tank to ? where by the fire wall? what do they attach too? i'll give it a whirl!
casey in SD
