Tool Talk Discussion Forum
how can i drill a 1 inch hole in glass block?
mr2255
12-13-2004 05:11:36
any ideas? thaks for your time. eric
Big Jim
12-13-2004 18:49:33
 Re: how can i drill a 1 inch hole in glass block? in reply to mr2255, 12-13-2004 05:11:36
Link
Harbor Freight has a set of diamond hole saws including a 1" for $9.
Ray,IN
12-13-2004 20:36:50
 Re: how can i drill a 1 inch hole in glass block? in reply to Big Jim, 12-13-2004 18:49:33
They work! Use terpentine for lubricant/coolant to carry cuttings away. Build a dam around the site with plumbers putty and fill with terpentine, then use only the slightest amount of even down pressure, preferably in a drill press for more even cutting. Allow the diamond cutter to do the work or you'll break the mirror/glass, whichever you are cutting.
Bud in NC
12-14-2004 04:42:28
 Re: how can i drill a 1 inch hole in glass block? in reply to Ray,IN, 12-13-2004 20:36:50
Sounds good except you need to use WATER as a lubricant/coolant! I"ve drilled 1/2" holes in about 50 glass blocks for SWMBO so she could make Christmas decorations. I tried WD40, dark cutting oil, 3 in 1 oil, kerosene - water works best - and you can clean it out of the block! Any type of oil leaves a residue that"s hard to remove. The blocks I drilled had a vaccuum inside so it sucked the oil right in. Water works better and is MUCH easier to clean up!
Vern-MI
12-13-2004 06:20:18
Use a 1 inch copper tube and lapping compound or use a carbide burr bit in a dremel tool.
