Tool Talk Discussion Forum
Black And Decker 331 seat grinder
John in Missour
12-11-2004 16:30:30
I have a seat grinder that just bit the dust.
The gears in the angle nose are gone (I think).
Does any one rebuild these or do I have to buy a new one?
If the vote is for a new one what do you recommend for some one that does this a couple of times a year?
lucass
12-11-2004 16:58:56
 Re: Black And Decker 331 seat grinder in reply to John in Missouri, 12-11-2004 16:30:30
i got an air drill and adapted it to work on my kwickway seat grinder, i know not tha same as bd but maybe you could swing it. lucass
george md
12-11-2004 16:57:56
John, Mine didn't fail but sure got tired of handling that big heavy beast all day. I took the hex ball driver off and mounted it on a piece of 1/4 inch stock , mounted that in a reasonably high powered air die grinder . Worked so well that when I changed from B&D to souix , that I bought the shaft for an electric driver (souix) , ground the end in the lathe with tool post grinder to fit the die grinder . Been ten years and I would not go back to electric drivers . If you need pictures or anything ,unhide your email and I'll send what ever you need .
george
John in Missouri
12-11-2004 22:36:05
 Re: Black And Decker 331 seat grinder in reply to george md, 12-11-2004 16:57:56
Hi George
Sorry about that I didn't see the hide button when I posted.
That sounds like the way to go.
I will try and get the nose apart tomorrow and try it.
John
george md
12-12-2004 10:46:04
 Re: Black And Decker 331 seat grinder in reply to John in Missouri, 12-11-2004 22:36:05
John,
I'm going out to cut wood , I'll get you some pictures tonite. No need to take the nose apart on B&D , the hex ball is separate .
george
