These Small MIG Boat Anchors
Greg
11-29-2000 16:08:36
"these get a lot of bad press, but that's probably from the 110 volt models being used for what they are not capable of." (Jimmyzz from thread down below)
There's a wealth of truth and knowlege in his statement.
The 110 volt or the smaller (<200 amp) MIGS are much more affordable than ever. First time welders especially need to realize and understand the small niche these machines fulfill and the limitations of the GMAW (MIG) process when working with different metals. (Know when to go to stick, right FredOH?)
One example of a limitation is the limited types of filler metals (wire) available. Another is understanding that amps equals heat. Heat translates into penetration.
Don't expect to run with the big boys when using these smaller machines with an extension cord *grin*.
Alberta Mike
11-30-2000 19:41:04
 Re: These Small MIG Boat Anchors in reply to Greg, 11-29-2000 16:08:36
I was in the market a few years ago for a small, 110V mig welder and I couldn't believe the price spread, even in the 'same' amperage range. The fellow at the welding shop told me to buy the most expensive one I can afford, and I bought a pretty good Miller brand welder and paid 3 times as much as some of the cheaper ones. Needless to say I haven't regretted doing it. I get very nice results up to 3/16" and occasionally even 1/4" without too much problem. I've run into guys that bought the cheap ones and they have had nothing but complaints. I guess the old saying that you get what you pay for applies to this situation.
Frd OH
11-30-2000 05:32:17
Heck, I always thought that a Mig was something to fight with. I guess to really make a Mig do it's thing, you grab hold of a stick! L8R----Fred OH
Greg
11-30-2000 09:11:40
 Re: Re: These Small MIG Boat Anchors in reply to Frd OH, 11-30-2000 05:32:17
Yeah! Both types are something to fight with.
Nah, don't fight them MIGs you just have to get "smarter than the" machine. When you have a dirty-worn liner & feed roll tension is off, you've just aced 3 tips in 10' of wire....Your ready to tear your hair out....Just think of what you can $ave on shampoo. ;*}
mike
11-30-2000 03:07:50
friend has a small 110 mig that works fine on light work.1/8' is fine;1/4 stock it won't penatrate. Also won't weld through rust, grease etc. Use em for what they're made for and you'll be fine.
