Get a drill point gage, about $8-20 from machine tool catalogs/industrial suppliers Get a new about 1/2" drill. Hold it to the belt sander (best) or grinder (works but not as easy) and study how to hold it togrind the angles.Do this with the belt sander off until you are ready to grind a dull drill. Hold it with the cutting edge you are sharpening up,shank of the drill to the left. The cutting edge should be horizontal. The shank lower than the point by a little. When you grind a slight upward motion of the point works for me. You need to grind each side (cutting edge) equally and to the same angle, holding the drill in the drill point gage tells you this. the leading edge,(cutting edge) needs to be "higher" than the trailing edge or it won't cut. To tell this hold the drill verticle infront of youwith the point up, slowly rotate it and see if thecutting edge is higher than the trailing edge. It is easier to learn on drills in the 5/16 go 1/2" range I think before going smaller or larger. After grinding hand stone the edges to a smooth surface, not changing the angles, to make the drill stay sharp longer. With a little practice you can save yourself the cost of a Drill Doctor, which works for a wile, but as the stone wears or the bushings wear, will not work as well. Some drills just don't seem to go well sometimes,but can usually be made to cut. If you get one of these, put it down and tr another one, come back to it later after you find it wasn't you, but the drill that was the problem.
