Can you braze with?
jake from il
10-28-1998 21:26:20
I don't currently have access to an oxy acel torch
can I braze with mapp gas?
chuck davis
11-01-1998 22:10:05
 Re: can you braze with? in reply to jake from il, 10-28-1998 21:26:20
: I don't currently have access to an oxy acel torch
: can I braze with mapp gas?
Mapp gas,propane,propolyene are not hot enough to do the job right.
Mongo
10-30-1998 14:33:00
Depends on the size of what you're heating.
Imagine it as cooking with a cigarette lighter. If all you want is a small piece of bacon, you're OK.
If you're trying to cook the whole hog, you're going to be unhappy. I've sucessfully brazed with a Propane torch. But the item was small. The problem is heat disapation. The bigger the item, the faster it's going to dissapate the energy you apply...
