Hi Grant, I bought a Stihl MS 361, decompression valve (DV), with a 20" bar with a 3/8", .050 RS chain. It appears to be a really nice saw. I didn't like the way Stihl recomends starting on WOT so I adjusted the carb for a idle start. A cold start is 3 pulls full choke WOT, 1 pull at idle. Warm is 1 pull idle. All using the DV. The Elastro-start opition is not needed with the DV. I have less than one tank of gas thru it so it's really too early to tell much more. Several things to try with the 7014. Ironpowder flux makes for a finished heavy flux coating. That means you need to use more amps with this electrode with about a 15% angle with a close arc length. Although 7014 is rated for all positions it's really makes a good rod for flat work with lots of heat and fast travel speed, thus it's intended design. A slightly wider root opening will help with the finished bead contour. Being ironpowder flux moister content is a concern. Try drying 5lbs or so in a oven at 250� for a hour and see if you can tell a difference. Your area may demand to keep this electrode in a rod oven before use. This would not be a good rod choice for short weld joints. 6011 would be a better slection. Yes there are some very talented people here and making the question open to all is a benefit to all. There's always more than one way to skin the cat. I never mind that someone else answers the questions, in fact I encourge it. T_Bone
