Tool Talk Discussion Forum
befor I weld 3/4 drive rachet..options??
diggerdave
12-07-2004 11:27:50
HI I was give an no name brand 3/4 drive rachet and socket set. To me the drive itself seems to be fairly beefy and substantial. Only problem is it is missing the "back" plate and probably a ball bearing selector? Since its noname i wasnt even going to try to fix and since I already have a complete set of 3/4 craftsmans drives, I was thinking of just welding it shut in the "off" position. This way I can have a "sacrificial" bar. ANy thoughts b4 I do this? Any other ideas. thanks dave
T_Bone
12-08-2004 05:04:16
 Re: befor I weld 3/4 drive rachet..options?? in reply to diggerdave, 12-07-2004 11:27:50
Hi Dave,
This is really a crap shoot on this one as who knows what the steel is like. I think I would heat the opposite end to a dull red then let cool then run a bead around that end. Let cool then check for cracks.
If no cracks after couple hours, reheat too a dull yellow (straw) and quench in oil (adds hardness), then reheat to 500� (lead melts at 500) then quench in oil adding temper.
If this turns out well then do the other end that your really wanting fixed.
T_Bone
TomH
12-07-2004 16:42:53
There's no loss if welding it doesn't work. Just don't trust it too much if you really lean on it.
On the other hand, they make pretty good hitch pins...
