Hi Mark, Last I looked, your new HF was essentially the same as the CH I bought myself 6 years back, I paid $179. back then and used it to build a 1200 sq ft cottage over a 1200 square ft garage/shop. I've been using Bostich glued nails with nary a jam, good gun! I had to laugh, as others experiences with noise and hoses are the same as mine. Throw in having to use a generator for compressor power and at times it seemed like a chore, but I guarantee even with all that, I saved 2-4 hours per DAY vs. hand hammering. I was so happy that I bought a roofing nailer just for that job. I too worked by myself with help from the wife setting the stud walls in place. I also used metal attached box nails for the sheathing and found that I had to lower the air pressure and only use one stick at a time to avoid jams, then it went well. I also have a 18g brad nailer from HF bought cheap. I went through three of them before I figured out to use only 80-85 lbs of pressure, 90-100 would break their pistons or jam them down. Since then, I have used at least 2k 1 3/4" brads with no jams or breakage, not bad for $25. I too would never consider HF stuff everyday construction tools, but why tie up hundreds of dollars in high dollar stuff to sit on the shelve 95% of the time? Kevin
