Tool Talk Discussion Forum
Electric log splitter
Ludwig
12-06-2004 15:38:51
Some time ago we talked about electric log splitters and it seems the consensus was "I dunno" did anybody ever get one?
On the farm we've got spruce and poplar for our firewood. I know, less than terrific choices.
Spruce I can split, no worries. Even large rounds come apart pretty easy, we've got one old axe that cuts through like butter. Big poplar rounds on the other hand are a severe PITA. Bury the axe head in a million times and they'll finally come apart.
This year we had our first chimney fire, second year with the woodstove in the camp. It was no big deal, roared like a jet engine for a few minutes then went out. The stove pipe is 6" up through a 12" pipe up through the roof, its a pretty safe setup actually.
The fellers had been burning green spruce for a few days because I cut a bunch of it last fall both because those trees needed to go anyway and because I could split it better.
We don't need so much wood that investing in a gas powered splitter is worth it. In a really heavy year we might burn a half cord of wood...
So pricewise the electric splitter is really the way to go, otherwise I'm thinking the rental route will be the way. I could cut smaller trees but larger rounds add up to more wood in the same time because there isn't as much limbing involved.
gabby
12-08-2004 06:15:30
 Re: Electric log splitter in reply to Ludwig, 12-06-2004 15:38:51
Rental sounds like the way to go. But first I"d consider two things.
Do you know anyone with a splitter and work out some sort of labor trade.
Can you cut anything other than spruce/poplar?. Hardwoods could provide more BTU"s but more importantly are alot safer.
Ludwig
12-08-2004 10:57:34
 Re: Electric log splitter in reply to gabby, 12-08-2004 06:15:30
Yeah, bamagiliad (sp) but you have to watch the water pour out of the tree when you cut it...
And a small portion of pine. ;p
Poplar is a hardwood, but I understand what you're saying, its not a particularly hard wood nor does it burn particularly well.
I do have a friend who has a splitter I could borrow but never a lender nor a borrower be, especially on something that could break easy.
I think rental will be the way to go.
That and hit every sawmill around to get hardwood scraps that'll burn hot.
Acutually in retrospect when dad and I were talking about the chimney fire we realized that as long as the fire doesn't get hot enough to melt/burn through the stovepipe its actually not such a big deal since the secondary pipe protects the camp from the heat. The outer pipe used to go down to a big old franklin stove. We couldn't find a sizer to fit it so we just ran the 6" pipe up through the center, sleeved it at the top and put a cap on the 6" pipe...
