The start capacitor and run capacitor can be distinguished by what they look like. A start capacitor is generally enclosed within a plastic housing while run capacitors are in metal cans. The start capacitor is also the higher microfarad value (generally in the low hundreds). The run cap on the other hand is usually quite low (often below 50 for most farm applications I deal with). The purpose of a start capacitor is to shift the current 90 degrees ahead of the voltage (or at least that would be the optimal shift). The purpose of a run capacitor as stated before, is to correct the power factor. This lowers the amperage draw of the motor and increases efficiency. If you happen to have a decent fluke or equivalent meter you can test the capacitance to be sure the capacitor hasn"t changed in value due to a loss of electrolyte. You can also test for a defective capacitor using an ohmmeter. Place one test lead on each side of the capacitor. - If Fauly - The meter will stay at 0 (shorted capacitor) The meter will stay at infinity (open capacitor) - If Good - The meter will temporarily read zero (or near zero) but then gradually climb towards infinity *To repeat the test reverse the two leads of the meter
