Tool Talk Discussion Forum
New Holland TC29 stopped running
Giancola
12-05-2004 06:35:12
Hello. I have a New Holland TC29. Yesterday, I was running the tractor and all of the sudden it stopped. I cleaned the battery terminals, but same result. It is churning when trying to start, but will not turn over. It sounds like it is not getting fuel. I checked the fuel filter, by taking it off. I emptied the fuel filter plastic reservoir and put it back on, but when turning the fuel valve to open, fuel does not fill the reservoir. Should fuel empty into the filter"s reservoir? Does anyone know if this might be a fuel pump problem. I do not know much about tractors. This is my own tractor and I have serviced it since new. It has 368 hours on it.
paul
12-07-2004 08:30:50
 Re: New Holland TC29 stopped running in reply to Giancola, 12-05-2004 06:35:12
I would suspect the bad electrical parts mentioned caused your problem. If so, then you _also_ have the air in the fuel line problem, and need to also bleed the lines.
Your description of the engine trying to start is extremely confusing. Does the engine turn over, or not with the starter? 'Churning' is kinda confusing, then you say it doesn't turn over, but you say it is not getting fuel..... If it truely is not turning over, then you have other problems as well. Huh????? :)
--->Paul
RickB
12-06-2004 14:32:48
Look for a blown 7.5 amp fuse.
BurlGoat
12-06-2004 05:07:59
The same thing happened to me.There is a solenoid on your fuel pump it is probably shorted and has blown the fuse to it.Mine did as yours did was running fine then just quit like you had shut the key off it would turn over like it was trying to start. HTH Burlgoat
greenbeanman in Kansas
12-05-2004 13:18:22
We may be on different thoughts with terminology, but let me try to help some.
I have a 1720 Ford which would probably be similar, assumming this is a diesel.
When I empty the plastic fuel bowl and replace the filter I don't tighten the ring and bowl into position until I have turned the fuel back on and allowed the air to escape while it fills. Once full I tighten the retainer ring to the proper tightness.
On the diesel pump there is a small hand pump, usually with any diesel you must loosen it by turning the knob of it backward or by some other means, and then lift it.
There will be a bleeder screw or bolt which you must loosen so that when you pump the lines back full of fuel the air can escape.
With the bleeder in the open position a few pumps should bring fuel to the bleeder. Tighten the bleeder, place the hand pump back as original, and the tractor should attempt to start when you engage the starter.
If this is a gasoline tractor then the above will not apply. If a gas tractor stops dead it is usually the result of an electrical failure rather than fuel.
Dell (WA)
12-05-2004 13:04:42
Giancola..... ....you'd probably gitt better answer faster at the YT Ford-Board rather than this tool-board.
Howsomevers: Iff'n you bought your TC29 NEW, then you should have owners manual. Have you read about "bleeding" your diesel? Thats the ONLY way to gitt that air-bubble outta yer fuelfilter.
Theres alotta reasons diesels quit and they's ain't all stricktly fuel. You should have an electrically opperated fuel cut-off solenoid, check that wire.
Your starting description is somewhat confusing. Watch yer fanbelt while you're crankin' yer engine, it gotta turn to run yer waterpump and alternator. That'll clue yer engine turn-over vs starter drive engagement question..... ....respectfully, Dell, the clue-less
