Tool Talk Discussion Forum
Thinking about a TIG welder
Lavoy
12-04-2004 18:39:57
I would like to buy a TIG welder to do some sheetmetal work on some reproduction parts I am making. Wire welder won"t really work the way I want in this instance neither will spot (I have both). Was at my local welding supplier the other day getting C25 and they had a neat little 150 amp Miller inverter stick/MIG. Comes in a kit with everything you need except another gas bottle, for about $1000. It is DC only so can"t do aluminum, but if I needed to do that, I would get a spoolgun for the MIG.
Anybody got one of these little rigs, how do you like it? I am going to be an occasional user, and price does matter, so can"t be buying a big fancy one with all the do-dads.
Lavoy
T_Bone
12-05-2004 22:07:23
 Re: Thinking about a TIG welder in reply to Lavoy, 12-04-2004 18:39:57
Hi Lavoy,
Scratch start Tig works well and can be used on any DC, CC machine. All you need is a Tig torch, flow meter, and a cover gas.
Below is a past thread on the subject;
Scratch start Tig is very common and has been around for many years, 60yrs or so. You lightly touch the tungsten to the metal, like striking a match, then pull back off the metal establishing the arc.
Nothing fancy needed, Tig torch, flow meter, AR for cover/purge gas, and a DC machine using straight polarity. You set the machine amps then fine adjust welding amps with travel speed.
My dropper resistor trick can also be used here.
To use that machine effectively then you need to use a dropper resistor made from a piece of 3/32" or 1/8" filler rod, depending on the amount of amps you want to drop.
Attach the 1/8" filler rod to the welding bench with a vise-grip and let it hang vertical then attach the ground clamp to the other end of the filler rod.
As the arc is established the filler rod (dropper resistor) will begin to heat thus lowering out-put amps at the torch.
CAUTION as the filler rod can become cherry red depending on the amount of amps being dropped.
To adjust for the correct amount of amps required of the weldment, one could trim the filler rod to different lengths or change the diameter although I've never found this to be necessary.
T_Bone
Lavoy
12-06-2004 09:00:59
 Re: Thinking about a TIG welder in reply to T_Bone, 12-05-2004 22:07:23
I have found some inexpensive scratch start inverter TIG"s. Only about 100 amps, but I am not going to be welding on anything very thick. Most say you need to buy the tungsten, how expensive are they, and what kind of life expectancy?
Lavoy
mike brown
12-06-2004 10:54:33
 Re: Thinking about a TIG welder in reply to Lavoy, 12-06-2004 09:00:59
You will need to buy tungsten electrodes. 1%or 2% thoriated tungsten alloy for steel. Pure or zirconiated for aluminum. I don't recall them being very expensive and they last quite a while if you don't accidently dip them in the puddle like I seem to do. With tig the elctrode does'nt touch the base metal but hovers over it and the arc forms the puddle.
T_Bone
12-06-2004 22:57:46
 Re: Thinking about a TIG welder in reply to mike brown, 12-06-2004 10:54:33
Hi Lavoy,
Use the 2% thoriated tunsten. I think about $23 for a 7 pack. Been to long since I bought new ones.
Below is another thread I posted early on;
As the other posters pointed out 3/16" is way too large. I only like 3/32" for 99% of my Tig work with 1/8" for AL welding only.
1/16" is very easy to bend as when you "stick" it or it'll break. You'll do that a few times when you first get started learning Tig.
How you sharpen your tungsten determines what kind of arc is produced at the tip. Using 3/32", I tapper the last 3/8" to a very sharp point as this gives the best arc stability. Let it protrude 1/4" to 5/16" past the cup lip. This gives you a very adaquote visual on your arc. 3/32" works well down to 30ga metal and unlimited thickness.
I break the tungsten in half then sharpen both ends. Score a line with the bench grinder before breaking. I use a piece of 1/2"CU pipe 7" long with two CU ends caps, Tig tack weld one cap leaving the other loose, for a great tungsten holder. I use one for each type and size of tungsten to keep them seperate.
Argon makes the best all around cover gas and is the cheapest. Mixed gases cost about twice more and have an advantage when welding some metals but for home shops it's not needed. You'll want about 10cfh or approx 3psi. Use your cheek to test gas flow, hold the torch close (NOT touching LOL) and you should feel a gentle gas flow on your cheek. That is if your inside a shop, outside takes what ever gas it takes to over come the breeze. Purge gas should be 1/3 flow of the cover gas.
A #7 cup is the best all around cup size. Only when I'm welding pipe do I use a different Tig set up. I'll cover that another time.
A HF box is not needed nor required for 90% of Tig work but if you have one use it as it makes starting a weld puddle easy with less tungsten contamination. There's alot of other uses for a HF (high frequency) control that I won't cover here.
Be sure and preclean your weld zone with a SS wire wheel 1/2" on either side of the weld, to white metal. The wire wheel will grab when you hit the white metal base.
Besure to use all glass lens for your welding hood both colored glass and clear glass. While Tig welding you will see the double weld puddle I've talked about in the past from using plastic lens that caused distortion.
T_Bone
wdTom
12-05-2004 17:47:07
Make sure you get a foot control to vary the "heat" as you weld. Maybe what you're looking at has this? I have TIG welded with and without the foot control and it is a lot nicer with it. Rectntly I bought a Lincoln Precision TIG 185, which will do stick and TIG, AC and DC,I am very pleased with it. It is a lot more than you were talking though and maybe more than you want. I started out just thinking on getting DC, as I have a Lincoln buzz box (AC only)which I am pleased with for most things. Once I started getting into it though one thing led to another and I ended up with this. I shouldn't have to add or upgrade for what I do now though. This is great!
Little Ed
12-05-2004 17:02:46
I recomend the advice to try to find a used older unit. That's what I did, but then I wanted the AC TIG capability. However, if you do not want to wait, you can't really go wrong with the little suitcase unit. We use one to repair injection molds. It is a 110 and 220 unit, an unusual brand, which I can't think of right now. On occasion we are using it at about two amps, but it will go up to about fifty amps on 110. It works really nice on sheet metal.
mike bbrown
12-05-2004 08:32:41
If you look around and be patient I'll bet you can find an older model tig with all the bells and whistles for about what you are looking at in the store for the new one that has some limitations. It won't be a small package however, so if space and portability are considerations an older unit may not be your best choice. My experience is that the old machines do beautiful work for a good price if you can live with the large size.
Lavoy
12-05-2004 14:35:45
 Re: Thinking about a TIG welder in reply to mike bbrown, 12-05-2004 08:32:41
Size in not a major concern, but I did like the idea of being able to put it in the case and set it on a shelf when not in use. There could be extended periods where I do not use it, so this could be beneficial.
Lavoy
Roy Suomi
12-04-2004 20:41:25
Hey Lavoy , I've got a Snap-on mig welder at my shop at home. It came with a spool gun and standard mig gun. The book shows that a TIG is also available for this welder. Can you get a TIG to fit your mig machine???
Lavoy
12-04-2004 21:01:44
 Re: Thinking about a TIG welder in reply to Roy Suomi, 12-04-2004 20:41:25
Don"t know, but I am going to check on Monday, thanks.
Lavoy
