A-C Model C Engine Rebuild ?'s
Kipp AK
11-26-2000 13:53:09
I want to get an engine rebuild instructional video, but can not find one for my model of tractor. It is a 1948 Allis-Chalmers Model C, 4 cylinder gas. Are any videos available?
I am just begining my first tractor restoration project. I found it at a yard sale. There aren't many antique tractors in the state (Alaska), so I jumped at the opportunity. It's fairly complete. The sheet metal looks good overall. The engine was in place, but partially dismantled. The valve covers and head were loose, with the bolts and lifters stored in a coffee can. Currently the block, head, etc. is at a machine shop in Fairbanks getting cleaned up, and the crank ground. I plan to purchase a rebuild kit from Mike's Tractors online. Has anyone gone that route and if so, do you have any advice? Thanks in advance for any assistanc
ltf in nc
11-28-2000 19:05:53
 Re: A-C Model C Engine Rebuild ?'s in reply to Kipp AK, 11-26-2000 13:53:09
Have not used the source that you are considering but I have been satisfied with the engine repower kit from Shoup 1-800-627-6137. Their kit for the C is $469.39 You get the sleeves and pistons,pins and retainer, rings, upper and lower gaskets, rod and main bearings. This will give you something to compare prices with. Good luck.
