Tool Talk Discussion Forum
air compressor question
waltertn
12-02-2004 12:05:46
Are the Farm Hand air comprressors any good? Local TSC has a 60 gallon one on sale for $430.
farmall300u
12-02-2004 22:31:27
 Re: air compressor question in reply to waltertn, 12-02-2004 12:05:46
For that kind of monies, you should be able to buy a first class compressor like a Quincy. I bought a portable Quincy QTS Series 3 1/2 hp 20 gallon portable for $369 in 1999. Oil filled, 2 cylinder single stage. 8.1 cfm at 40 psi and 6.7 cfm at 90 psi. Runs very quiet and has proven to be very tough during the past 5 years.
Quincy used to make a 30 and 60 gallon in the QTS-3 series with either a 2, 3.5 or 5 hp motor. Not sure what the price would be today. Google search might show it.
Roger P.
12-02-2004 21:28:16
It's a rebadged Campbell Hausfeld, which isn't a bad machine at all. Horsepower ratings are laughable, but size it by CFM delivery to the tools you are going to use and it should do just fine.
FarmerDave
12-02-2004 16:01:49
If I remember correctly when the air compressor manufacturers got hauled into court for bogus numbers Farm Hand was really Campbell Hausfeld. In my market TSC and Walmart are just a block apart so they can both be the cheapest. Other than listing bogus performance statistics nowhere on the web have I seen people running CH down. Probably they are not professional quality but that may not be your priority either.
CNKS
12-02-2004 14:01:49
The brand doesn't mean much as it's some companies compressor with a "store" name on it. Whether it's any good or not depends on what you run with it. Probably puts out around 10 SCFM at 90 psi -- those are the numbers you need to know along with the air requirements of your tools.
dr.sportster
12-19-2004 08:04:51
 Re: air compressor question in reply to CNKS, 12-02-2004 14:01:49
This is just hearsay,as judge judy would say,but I heard Campell and Hausfeld were two engineers from Ingersol-Rand that started thier own thing.I have a fake 5 horse from Home cheapo.It works for a bead blast cabinet,constantly supplying enough air.For the sandblaster there is some waiting time,but not too bad.The price was good at about 500 bucks.No way is it an actual 5 horse electric motor,but it works.Your concern is CFM requirements.
