Tool Talk Discussion Forum
Trailer wiring
Roy B
12-01-2004 20:21:47
Can any one tell me if the color code for a 7 pin, RV style, connector is the same as a 7 pin, round pin style connector. I am making up an adaptor and I seem to remember it not being as simple as hooking blue pole to blue pole ect. Thanks for any help. Roy
rotten robert
12-02-2004 17:53:12
 Re: Trailer wiring in reply to Roy B, 12-01-2004 20:21:47
Ok here we go looking from the back of the plug
Big pin at the top - White - Ground
in a clock wise pattern
Black rear tail lights
yellow turn
red stop
green turn
brown running lamps
Blue in the center BU lamps
Bad case of CRS right now but green and yellow are the turn signals and not all setups use the black wire if the brown wire is running all the rear markers as well as side markers.The big pin makes an excellent redundant ground rather than relying on the hitch to complete the circuit. Hope this helps.
Roy B
12-04-2004 07:21:20
 Re: Trailer wiring in reply to rotten robert, 12-02-2004 17:53:12
Guys, Thanks for the posts. Got it made up, now I can only hope the mill matches the code. Thanks again. Whats an Autozone? ;^). Roy
BB
12-06-2004 04:51:05
 Re: Trailer wiring in reply to Roy B, 12-04-2004 07:21:20
Don't know where you are located. Around here Autozone is one of the largest discount auto parts chains.
John *.?-!.* cub owner
12-02-2004 06:34:00
Walmart and Autozone both sell the adapters to go either way for about 12 to 15 dollars.
BB
12-02-2004 04:32:07
Try this link.
