Tool Talk Discussion Forum
Don't know what it's called!!!!!
Nat
12-01-2004 19:24:29
Don't know what you call them, but I want to find one.! What I'm talking about is a tool that you chuck into a drill that is sorta funnel shaped and is used to cut a taper and a straight shank on a round piece of wood. I want to make some wooden hand rails for my porch and need it to turn the ends of the picketts so that they will go into a 1" hole in the in the rail. Does anyone know what they are called and where to find them? Thanks, Nat
Nat
12-02-2004 18:38:43
 Re: Don't know what it's called!!!!! in reply to Nat, 12-01-2004 19:24:29
Thanks a bunch. Now that I know the name I did a gogle search and found plenty, but I don't think gogle would find it with my description. Thanks Nat
john in la
12-02-2004 06:08:37
Well let me add my 2¢
You are looking to make a round tenon. You can do this several ways.
First you can use the tenon; dowel; plug cutters you can find most anywhere that sells woodworking tools. These tool are mostly made for making plugs but could be used for tenons. You may find you still have to cut off the outer part as the tool may not cut all the way to the edge of the post.
Second way is with a true tenon cutter. These tools are just for making tenons and are much better built. They also cost more than twice what a plug cutter cost.
third party image
treelineusa.com
Third way is to use a router and a straight cutting bit. You need to make a jig to do it this way. Make a wooden box. Cut a hole in one side that your pickett will just fit in. On the other side cut a hole the size of the tenon. In your case 1". In the top cut a hole for the router bit to stick through and mount the router to the box. Adjust the bit so that when you turn the pickett it cuts all but 1" center to make your tenon. The cut tenon comes out the other side. You could put a stop on it so every tenon is the same length.
This is also a great way to make long dowels out of different kinds of wood.
ArtinNY
12-02-2004 04:50:18
Woodworkers Supply part #122-093 is for cutting a 1" tenon. Their number is 1800-645-9292, or www.woodworker.com
J.C. IN AZ.
12-02-2004 08:10:17
 Re: Don't know what it's called!!!!! in reply to ArtinNY, 12-02-2004 04:50:18
1-800-Rockler will get you the information you are requesting or Wood Workers Supply as some one else suggested.Rocklers calls the Tool "Logman Tenon Maker"
VaTom
12-02-2004 04:07:54
Hi Nat,
The joint you're wanting to cut is a tenon, requiring a tenon cutter. Tenon goes into the (round) mortise in the rail. Not a very strong joint, but may be adequate for you. Windsor chairs that use a similar joint have a tapered tenon which then self-tightens any time somebody sits in it.
I hope you're talking about the top rail because that joint into a bottom rail will give a great path for rain to get in and greatly decrease the lifespan. If you're using a bottom rail, a better joint would be to cut an inverted V on the rail and notch the picket bottoms to fit.
Eddie Petty
12-02-2004 03:23:00
...dowel maker !!! Link
Jim O.
12-02-2004 03:12:51
Countersink Drill Bit
Jim
kraigWY
12-01-2004 22:40:29
I know what your talking about but for the life of me I can't think of the name. Go to to www.diynet.com and seach for the project, rustic porch swing made from saplings. They used the too there and the artical will tell you where you can get one.
poor tom
12-02-2004 04:10:36
 Re: Don't know what it's called!!!!! in reply to kraigWY, 12-01-2004 22:40:29
They're called tenon cutters and Lee Valley Tools sells them.
