Tool Talk Discussion Forum
Craftsman Radial Arm Saw model 113.29460: wiring
John Ott
11-26-2004 15:48:45
I bought a used craftsman radial arm saw. It's a
model 113.29460. The wires have been pulled off
the terminal block inside the motor. Does any one have a wiring diagram? I know how to wire the motor for 120/240 but not the incoming power or outlet for the light.
John Ott
11-27-2004 04:52:09
 Re: Craftsman Radial Arm Saw model 113.29460: wiri in reply to John Ott, 11-26-2004 15:48:45
The Sears web site only has the owners manual posted. The only wiring diagram is for 120/240V wiring.
I'm still having problems.
terminal board on motor /wire color
1 blue
2
3
4
5 brown (120V)
6 orange (120V)
7 (240V)
8 (240V)
Power cable coming into motor has the black wire connected to a black wire from the motor with a wire nut. The remaining white wire has a female spade lug that's not connected to anything.
The guide light has a white and black wire with female spade lugs. Neither is connected.
Keith-OR
11-27-2004 22:28:37
 Re: Craftsman Radial Arm Saw model 113.29460: wiri in reply to John Ott, 11-27-2004 04:52:09
checkout this website on recall then go to their home page and see if you can find something there since they are the manufactures of Sears radial arm saws.
HTH.....Keith
MAC,IL
11-26-2004 17:07:21
John:
Try putting the model number on sears parts web. There is a diagram there, but a poor one, maybe by checking the diagram against the parts numbers you can figure this out.
Rod in Smiths Falls, ON,
11-26-2004 17:40:20
 Re: Craftsman Radial Arm Saw model 113.29460: wiri in reply to MAC,IL, 11-26-2004 17:07:21
This is the motor for the two-yoke model, right? I ended up modifying one of those to fit into the casting for a one-yoke electronic model. My friend with a 20 ton press and a good eye did the deed, setting the bearing clearance by eye.
The motor was a bit long for the new case and I had to hang one capacitor outside on its wires as there wasn't room inside.
Anyway, the wiring is bone simple. The wires come in, you hook the same ones up either 110 or 220. Just be careful not to break any of the little crackly things in there. I had to epoxy something back together, as I recall.
The new motor was a vast improvement for the poor saw, and it has done an enormous amount of work since the jury-rigged repair. 220's no real advantage if you have good current. I stuck with 110 after trying both.
Hope this helps.
John Ott
12-27-2004 07:03:56
 Re: Craftsman Radial Arm Saw model 113.29460: wiri in reply to Rod in Smiths Falls, ON, , 11-26-2004 17:40:20
Rod in Smith Falls: After opening the motor up, I found I have a cracked motor housing(both pieces). I need to find another motor. It's too old for Emerson or Sears to sell me another. Do you still have your old one? Do you want to sell it?
