Tool Talk Discussion Forum
Generator loses magnetism ????
jCarroll
11-26-2004 05:43:42
I have little experience with backup/emergency generators - just borrowed 'em. Talking single phase, 120/240v units. Now I'm kicking the tires, and reading the posts. Every once in a while, someone mentions generators losing their residual magnetism. Give me a lesson on this:
Is this a "real" problem?
Does it affect every kind of generator?
What do you do to prevent it?
Other advice?
Bob M
11-28-2004 16:21:40
 Re: Generator loses magnetism ???? in reply to jCarroll, 11-26-2004 05:43:42
My experience is it depends on the generator. I've got a Coleman 4 KW unit that has sat as long as 30 months. But it always self excites immediately upon startup. But I also have an ancient US Electric 1.5 KW unit that must have the fields "flashed" if it sits idle for more than a few weeks.
Bob
11-26-2004 09:41:24
John and Coloken,
I work on small engines, and I can assure you the problem of losing residual magnetism comes up quite often with the newer gas-powered generators.
Coloken
11-26-2004 13:20:40
 Re: Generator loses magnetism ???? in reply to Bob, 11-26-2004 09:41:24
Thanks Bob I guess your never too old to learn. Hadn't run into it. Yet..... ..
John *.?-!.* cub owner
11-26-2004 09:37:01
With the very old generators it was sometimes a problem if they sat for several months. I've never heard of it needing to be done with the modern ones.
buickanddeere
11-26-2004 09:56:22
 Re: Generator loses magnetism ???? in reply to John *.?-!.* cub owner, 11-26-2004 09:37:01
The Coleman 5000 I got rid off would need the field flashed after three months if it wasn't used.
Coloken
11-26-2004 06:40:48
Don't worry about it. Most posts are about "polarizing" generators, 6 or 12 volt so they will charge the right way. Plus or minus. Kinda needed with a brand new one. If a piece of metal has once been magnetized it is all most imposible to completly "demagnitize" it unless you want to. Like a watch.
Bob
11-26-2004 06:37:51
In my experience some do, and some don't. The longer a unit sits without being used, or even started, the greater the chance of this happening.
There's an easy way to "flash" a generator, and get it working again, though:
Rockin' Farmer
11-27-2004 05:49:47
 Re: Generator loses magnetism ???? in reply to Bob, 11-26-2004 06:37:51
Well I'll be! A while back I fired up my Coleman 2500W plant that had been sitting for over a year, plugged in a trouble light to test the generator, and got nothing. Thinking the bulb was burned out, I grabbed my drill and plugged it in. Nothing. Gave the drill a spin with my hand, out of desperation, and it started running! Plugged the trouble light back in, and it worked! Been scratching my head about that one for quite a while. Now I know what I did!
All this time, I've been blaming "Evil Spirits".
Thanks for the tip!
Rockin' Farmer
11-26-2004 09:38:50
Bob, that's a good tip. wish I'd know about it when I used to own a 60 year old Sears light plant that I used for standby power.
Dusty
11-26-2004 08:28:27
That's a great way, I've never heard that method. The other way is to use a 1.5 to 6 volt battery, momentary connecting to the brushes, the generator must be turning/running while doing this. Polarity matters. I extended a wire from each brush, red on one and black the other, out to where I could get to them. Even a AAA battery will work.
Dusty
Stickler
11-27-2004 00:01:43
 Re: Generator loses magnetism ???? in reply to Dusty, 11-26-2004 08:28:27
I operate Hydro power stations for a living. Yes, all genreators are prone to this. We "flash" ours with a 8D battery to build it back up if it's been sitting for a long time.....a year or more.
