Mechanical Help! 1979 Ford 555 backhoe
Chris Hunter
10-26-1998 19:17:47
Help! My tractor (backhoe) won't start...so I changed the fuel filters, then bled the filters and also fuel pump with bleed screw but still not getting fuel to injectors ....any suggestions would be appreciated. I just purchased this tractor so I not too familiar with it. I've only worked on old farm tractors (they had a prime pump to bleed system, I guess this newer stuff doesn't?)Appreciate any help.
Thanks, C Hunter
james
11-03-1998 07:24:24
 Re: Mechanical Help! 1979 Ford 555 backhoe in reply to Chris Hunter, 10-26-1998 19:17:47
: Help! My tractor (backhoe) won't start...so I changed the fuel filters, then bled the filters and also fuel pump with bleed screw but still not getting fuel to injectors ....any suggestions would be appreciated. I just purchased this tractor so I not too familiar with it. I've only worked on old farm tractors (they had a prime pump to bleed system, I guess this newer stuff doesn't?)Appreciate any help.
: Thanks, C Hunter
Use an air hose and pressurize the fuel tank make sure you have fuel flowing from the inj. pump.Not just dribbling out and look for air bubbles.Crack one injector at a time and let the air purge out .Thighten the line while the engine is being cranked over.do the other lines in the same manner,let the inj.bleed for a fair amount of time.DO NOT LET THE STARTER OVERHEAT.GOOD LUCK
who
10-27-1998 11:36:12
: Thanks, C Hunter
open one or two injection lines and crank engine. fuel should come out
Robert Kvamme
06-17-2000 14:12:47
 Re: Re: Mechanical Help! 1979 Ford 555 backhoe in reply to who, 10-27-1998 11:36:12
It,s probaly dirt in the fueltank that is blocking the hole to the hose that leads to the fuel filter, try to disconnect the hose on the filter side and blow a litle air into the tank with a little bicycle pump.
Best Regards Robert Kvamme
krista
05-16-2006 13:09:38
 Re: Re: Re: Mechanical Help! 1979 Ford 555 backh in reply to Robert Kvamme, 06-17-2000 14:12:47
HELP!! i have a ford backhoe 550 and i am trying to replace the starter but cant get it out, if you could help me out, maybe let me know how to remove it, that would be great,
thanks!!!
krista
troy
07-16-2003 05:25:45
