Linseed oil and paint thinner is a good often practiced preservative measure to protect wood. I mix about 1 part L to 2 parts thinner and brush it on liberally. The thinner is a vehicle to help the oil penetrate the wood, then the thinner evaporates away. Makes water bead up; round on the bottom like Mercury. The water is either brought in via the auto, or condenses out of the air as the slab is cooler than the air (glass of iced tea sweating on your table). If you can seal the wood edges from the air, you have suceeded in sealing out the moisture..... like T-Bone said, but the linseed could do it too. Would have adequate ventilation and dry out wood first. Even if you have to do a little at a time. I live in Texas and installed a poly vapor barrier in the floor of the shop when constructing. Even then, on humid days, the floor sweats so unless you have a barrier and a sealed building (like a house) you will have some sweating. Don't know what your sole plate is made out of. If it's white wood be concerned. If it's SPIB Southern Yellow pine don't be. If it's one of the woods T-Bone mentioned wouldn't worry either. Builders in your area may use spruce which is a non worrier. One way you can tell is to take a sharp pocket knife and stick it. If it resists the knife, it'll resist the water. If not be worried. Amazing how much water wood (some wood) will tolerate and not rot. Had another idea. If your sole plate is bolted to the floor, you might loosen the bolts, little at a time, and get some 30# felt paper like is used for underlayment for a roof. Cut to fit and slide between plate and slab. I built a room on once, before treated wood was popular (thanks to the "deck" craze)and I did just that. Cut the felt in strips and laid it down and then erected the wall. If your plate is secured with nails it would be harder. Mark
