I know what you mean about being reluctant to hook your genny up to solid state stuff. At one property we have a 5 KW Honda wired in to an emergency panel and I wouldn't hesitate for a minute to use it for electronics because the power seems to be of very high quality with minimal surging. At this house all I have is a 1.65 KW Coleman, though, and I don't want to risk my gas furnace and circulation pump on it. If it gets cold during a power outage I'll try it, but not until. The thing is the Coleman produces lousy power. I have measured the voltage at various times between 95 and 135 volts. I shudder to think of what that does to the phases. Just for the fun of it I plugged the same 100 watt trouble light into each machine in turn. The Honda's light was even and smooth. The little Coleman's flashed a lot. I'll use the Coleman on electronic things only in an emergency. For the rest it can run a drill, saw or light just fine, and it's easy to move around. But a 12 kw generator is likely a lot more sophisticated than this little portable. My friend's 7.5 kw Coleman makes pretty good power. What if you rounded up a disposable computer and monitor, then rigged it up to run whenever you have the generator on and watched to see if anything bad happened over time? It could be fine.
