Tool Talk Discussion Forum
Decumseh Surging
Snow Blower
11-24-2004 15:17:12
I fired up the snow blower today and it keeps surging I have to put the choke at 1\3 choke to keep running and it still keeps surging and eats up lots of gas. last year when this happen the mechanic boilded out the carb eventually he got it running O K He said left over gas caused the problem. This Spring I ran out all gas till the motor stopped running and put it away. Now to day I still have the same problem. Please I need Help THANKS Much Frustration
lucass
11-24-2004 18:33:35
 Re: Decumseh Surging in reply to Snow Blower, 11-24-2004 15:17:12
even tho you run out the gas there is still some in the fuel bowl. i think if yotake off the fuel bowl and wash it out,and clean the passage in the bowl nut it should help. the thing to do is to treat your gas with stabil and keep the take full during storage,,yoknow to keep the air out of the tank..lucass
Larry Elgin
12-02-2005 11:30:47
 Re: Decumseh Surging in reply to lucass, 11-24-2004 18:33:35
I have a Toro snow blower that wont start. I think it needs a new Magneto with spark plug wire. Toro 526 ; 5 HP; Ser # 31626101930; Serial # 013516901. It Has a Decumseh engine.
bo
11-24-2004 19:52:24
It's hunting...carb needs cleaning. Forget "boil" it out..all that is is a carb soak. You could take it apart and spray out the low speed and high speed circuit but before you do, go to Walmart and get some B-12 liquid and run it through with the gas.. You have a bit of varnish in some little hole. While you're at it, get some B-12 spray and be prepared to take the carb apart if the fuel/b-12 doesn't work.
In the future, mix some Stabil into the fuel, fill up the tank and run it till the carb runs dry.
