Tool Talk Discussion Forum
home shop size
farmweldr
11-22-2004 09:10:42
i live on a 100' by 400' lot, with a house and garaage. i use the garage now for my shop, but it isnt big enough. im planning on adding a welder (likly a TIG) a compressor, plus my tractors that im going to restore. keep in mind that im not exactly the richest person and i need to have something that will fit and look good. if i build somthing that dosent, mom and dad 'll have a cow. i also own and operate a lawn care business, and will need space enough for a 6'by12' and a Zmower and push mower
andy b.
11-22-2004 17:44:48
 Re: home shop size in reply to farmweldr, 11-22-2004 09:10:42
you have several options. i use my garage as a shop as well (once or twice i've parked my wife's car in there when a big snowstorm is coming). the garage is 24'x35' and i can fit two disassembled tractors in there, two medium-sized milling machines, a small lathe, a 18'x3' workbench, a lawn tractor, another 10'x30" workbench, some storage shelves, a 5' finish mower, and a bunch of woodworking tools. notice i said i can FIT these things in there, it is difficult to use them. this summer i decided to clean the stuff out of the garage that really doesn't need to be in there (tractors, mowers, wood, etc.) so i built a 22'x32' polebarn. i did all the work myself so my only costs were materials. i used 6x6 posts and made my own trusses. the siding i got at the local sawmill (rough cut white pine) and i went with a metal roof. the polebarn is uninsulated and has a crushed stone floor. my total cost is under $5000, and i can easily fit four tractors and a ton of wood and other odds and ends in there (and still have room to walk around and get the tractors out). i figure i have the "real" garage to work on anything, and all the running tractors or projects that at least roll can go in the polebarn.
if you can use the garage for doing work, and use an outbuilding to store all your stuff, this may be the way to go. i used pressure treated wood for the footer board in the polebarn, so i can always pour a concrete floor if i want to at some point in the future (but i really have no plan to). the walls on the polebarn are 10' high, so i also have the option of adding a lean-to extension on a side if i want to put a roof over something that really doesn't need to be enclosed in the polebarn.
the polebarn fits in well with the rural location and the neighbors have all complimented me on it. if you can work out something like this on your property it may be the way to go. and honestly, i'm not sure how much of a building you could put up for under $5000 unless you used a lot of recycled materials or stuff you got good deals on at an auction.
good luck on your project.
andy b.
John Niolon
11-22-2004 17:01:39
sounds like the only way you can go is back. you didn't mention the roof design on the garage, but I'd hope the gables face front to back on the lot..
the easiest thing would be to add a lean too shed/addition to the side of the garage if the roof pitch is shallow enough to give you any head room. The shed roof doesn't have to match the roof pitch but it needs to slope enough to shed rain. You can add the roof and supports first, then add the walls as you can afford it
you could start with a gravel floor and pour a slab later as your lawn business generates more revenue.. That will at least let you get equipment out of the weather.
next option is to keep going back to the back lot line as far as your finances allow... but you're looking at a little more involved carpentry skills here... tying into roof line and extending walls... new footings and floor..
you didn't mention budget ??? how much is Dad in for ??? :-)
john
farmwelr
11-23-2004 18:24:50
 Re: home shop size in reply to John Niolon, 11-22-2004 17:01:39
yes it is front to back, but the lean too will be way over the property line. i have a concrete pad right behind and connected to the garage, so i might try to convince dad to expand on to this.
budget 1000-2000 dollars. not much, but ill get what i can
thanx
farmweldr
sorry my name keeps changing. i have to. the password screen wont accept my password. ive had to change 2 times in the last 2 days.
