Tool Talk Discussion Forum
Problem with old Co-Op welder
IHC Red
11-21-2004 23:06:39
It worked fine a while back last time I used it. Now it hums but won't arc, any ideas ?
The switch is goofy, but I don't think this is the problem because it hums.
T_Bone
11-23-2004 11:09:43
 Re: Problem with old Co-Op welder in reply to IHC Red, 11-21-2004 23:06:39
Hi Red,
Maybe 1/2 of breaker triped? Bad twist lock on a welding lead connection? Loose or corroded rod holder or ground clamp?
Short the rod holder to the ground clamp and see if it sparks? No spark, then enternal problems.
T_Bone
IHC Red
11-23-2004 17:59:18
 Re: Problem with old Co-Op welder in reply to T_Bone, 11-23-2004 11:09:43
Thanks for the reply...
I checked the cables as best I could... they're the "fixed" type. Used my DVM and I didn't get any reading.
It's on an old fuse-type panel box. It didn't occur to me that a fuse on one side could be out and that it would still humm.
I'll check the fuses and then open it up and see what I can find.
Assuming all connections are good, is there anything specific internally that is more prone to failure ?
Thanks again.
mike brown
11-24-2004 17:55:19
 Re: Problem with old Co-Op welder in reply to IHC Red, 11-23-2004 17:59:18
I have an old Craftsman that did somthing like that. It turned out to be the connections to the switch were corroded so it was trying to operate on one leg only. Cleaned it up and it has worked since. If it is in an unheated shop it is more prone to this.
IHC Red
11-24-2004 21:20:33
 Re: Problem with old Co-Op welder in reply to mike brown, 11-24-2004 17:55:19
That could be it... I hope it's that simple.
It's in an old unheated quanset... it could be 40+ years old.
Thanks.
