Tool Talk Discussion Forum
Milwaukee cold cut metal cutting circular saw
e
11-21-2004 07:54:59
Does anyone have experience with a 6370-20 milwaukee cold cut saw? This is the hand held one that uses a cermet blade(not an abrasive blade!!!!! !). I want to find a better way of cutting ribbed steel for our shop and am curious what people think of these.
Thanks,
Eric
Bill in Ohio
11-21-2004 14:50:20
 Re: Milwaukee cold cut metal cutting circular saw in reply to e, 11-21-2004 07:54:59
I bought one, based on my experience with the cut off saw with that sort of blade.
So far I have screwed up 5 blades, some almost immediately, and ran it long enough with a dull blade to burn up the motor.
I was using the coarse tooth blade, maybe where I should have had a fine toothed one, but, anything that is flimsy and vibrates will destroy a blade in minutes. That, from experience, includes heavy gage expanded metal and a car top.
Plunge cuts appear to produce enough heat to instantly ruin a blade, also.
I am fairly sure it would surprise you with its speed and nice finish on plate steel. Make sure it doesnt get pinched, though.
