Tool Talk Discussion Forum
mf65 no spark
ian
11-18-2004 09:09:57
i just finished a 4 month restoration of a mf65 gas tractor.
this morning i went to fire it up and i get no spark.
are there any tests i can administer to track down the trouble?
the ignition system is completely new.
thanks in advance
ian
old
11-18-2004 09:34:25
 Re: mf65 no spark in reply to ian, 11-18-2004 09:09:57
I'd start in the disb, check to make sure the points are hooked up right. In some of them you can short them out if not put in right. You might also try to hot wire it and see if you get spark, if you do, you have a problem from the coil back to the switch if you don't your problem is from the coil, to the plugs.
