Tool Talk Discussion Forum
Valve Seat Grinder
wbcelec
11-18-2004 03:58:14
Does anybody have a source for Black + Decker valve seat grinder operation manuals,stones & pilots?
george md
11-19-2004 09:05:06
 Re: Valve Seat Grinder in reply to wbcelec, 11-18-2004 03:58:14
wbcelec, Having made a living with B&D for 20 years and then changing to Sioux , I would quit doing seat grinding before going back to B&D . If you have not invested much in the B&D , I would look for a Sioux or Kwik-way . They are much better stone holders as they have 2 ball bearings carrying a sleeve that does not rotate on the pilot. B&D bushing holders spin on the pilot and their bearing model has one bearing at the top and nothing below .They wear out the pilots badly. If you want the top of the line grinder, look for a Hall- Toledo . It is an eccentric grinder with micrometer feed , but you won't like the price. I have a set of Sioux that I use regularly and a set of hall-toledo that I use for special jobs. The other thing with B&D is that B&D no longer makes seat grinding equipment .
george
JHesler
11-18-2004 10:58:46
Goodson's is the place to get stones and some pilots. You might have to make your own pilots if they're odd sized. I have a set of the original manuals. What is it you need to know? Are you talking about the refacer machine or just the seat grinder.
wbcelec
11-19-2004 03:28:56
 Re: Valve Seat Grinder in reply to JHesler, 11-18-2004 10:58:46
Looking for information on just the seat grinder.I noticed the B+D pilots have spiral grooves in them. What are they for? Does this brand of stone holder need a bounce spring? I am interested in the whole procedure of seat grinding.
JHesler
11-19-2004 07:37:48
 Re: Valve Seat Grinder in reply to wbcelec, 11-19-2004 03:28:56
The spiral grooves are oil ways in non ball bearing stone holders. No spring required, the tool vibrates against the seat. Just let the weight of the grinder do the work, don't push on it or the vibrator won't work.
Ron in Nebr
11-18-2004 07:27:43
Alot of that stuff comes up on ebay quite frequently, might wanna check there, just type in "valve grinder" in the search box.
rustyfarmall
11-18-2004 04:44:38
Here is agodd source for the stones.
rustyfarmall
11-18-2004 04:46:15
 Re: Valve Seat Grinder in reply to rustyfarmall, 11-18-2004 04:44:38
Never mind the fact that I can't spell this early in the morning.
