Welding cast iron
SLAG
11-21-2000 10:43:35
while repairing a Dresser 125 the cast? iron part of blade suport area was worn down badly,{on a six way blade} I used Nickel rod as Harris Tech said to do but, nickel seems too soft they said that hardfacing rod would not work. Any ideas,thanks
Gary
06-03-2001 07:50:30
 Re: Welding cast iron in reply to SLAG, 11-21-2000 10:43:35
Nickel rod is for welding cast. Airco 375 is a nickel rod for cast welding, works great. Thin cast you may want to brase.
T_Bone
11-21-2000 17:23:43
Hi slag, Look on Steve's US Alloy website as they have a rod that you can weld almost anything with then lay a bead of hard surface rod on top of that. I've never used the rod but the spec's sure look good.
T_Bone
FRED
11-21-2000 16:20:45
If it is a blade support it is most likely cast steel. Try to cut it with a torch. If it cuts preheat it and weld with 7018. FRED
jimmyzz
11-21-2000 23:13:19
 Re: Re: Welding cast iron in reply to FRED, 11-21-2000 16:20:45
fred's got it . i don't recall any cast iron in thar area at all. try 7018 you willo be able to tell from weld characteristics and bead.
Fred OH
11-22-2000 07:28:32
 Re: Re: Re: Welding cast iron in reply to jimmyzz, 11-21-2000 23:13:19
The guys are right, no cast iron here. Cast steel and a good tough alloy to boot, because of the service it performs. My choices of rod here would be 7018, 8018 or 9018. Lincoln makes a rod called BU90 that is a build up rod and it can be overlayed with hardcoat too, same as the above. Most generally, any place that is worn thin on a bucket or blade gets a patch of plate steel welded on it, usually as thick or thicker than the parent metal. If you're not sure of it's weldability, preheat it a little and weld a small piece of flat iron to it and see how hard it is to break away. Block her up good when your welding on it, remember a fellow up in Kenora, Canada welding on one and it fell on him and killed him. Hydraulic line decided to give way. L8R----Fred OH
BFO
11-22-2000 07:48:10
 Re: Re: Re: Re: Welding cast iron in reply to Fred OH, 11-22-2000 07:28:32
You're right, make sure everything is blocked up safely. Last one I did, I used 8018, and it worked fine. Don't know of any manufacturer using cast iron for this application. Bill
Slag, thanks
11-23-2000 10:13:47
 Re: Re: Re: Re: Re: Welding cast iron in reply to BFO, 11-22-2000 07:48:10
Thanks for all the good advice, an old saying go's the smarter you are the more you realize how little you know, or something like that. I think I'll offer to redo the guys blade this time useing 7018 or maybe 11018 never had a reason to use 8018 or 9018 with the psi rateings of mild steel at aprox.68-70,000 and the AR400 plate we used on lowbed trailers at 110,000-130,000 or so we were told.
Phill Walton
08-21-2001 18:10:22
 Re: Re: Re: Re: Re: Re: Welding cast iron in reply to Slag, thanks, 11-23-2000 10:13:47
Always preheat to atleast 900 degrees.don't let it cool to quick. Peen all around weld lighty while maintainig 900 degrees,this will releave stress while the metal in the weld is srinking.
Fred OH
11-23-2000 20:24:49
Bout the only thing that I use 11018 for is on cutting edges such as a shear blade. It's harder than Chinese Rithmatic and sure will dull your chipping hammer. L8R----Fred OH
