Tool Talk Discussion Forum
Torch popping
john in la
11-17-2004 09:56:13
What will cause a oxy/acc torch to pop ?
I am welding up some fender panels with a small welding tip but it does it also with my cutting tip.
I notice if you turn the gas to it the popping will stop. That much heat and cutting is ok but trying to weld fender panels is getting hard.
I got a new welding and cutting tip because I thought the tips may have been dirty even though I clean them. That did not help.
It does not pop all the time but will just start out of the blue. Does not matter if you are welding/cutting or just holding in mid air so back heat or holding tip to close is not the problem.
It will pop very fast about 20 to 30 times then quit and act correct for 5 or 10 minutes then start popping again.
It is a Victor. I think the model is 315.
Did not look at what size tip I have but could using to big a tip and turning it down cause this ? It still has a nice blue flame though.
If needed what is involved in rebuilding this handle and what should I expect to spend to have this done ?
Thanks very much
John †
john in la
11-18-2004 04:52:15
 Re: Torch popping in reply to john in la, 11-17-2004 09:56:13
Thanks Guys;
I kind of thought that was my problem because like I said if I turn it up it works a lot better.
I usually use coat hangers but decide I wanted a better job so I got some rods from the welding supply. Will get a couple of hangers and try that.
I think the real problem is the fact that the metal is thin in spots. You start with a 1/2" hole or a stress crack and by the time you got it welded its 1 1/2". BUT if it keeps messing with me I will go to plan B and break out the fiber glass.
Thanks again
John †
JHesler
11-18-2004 17:02:38
 Re: Torch popping in reply to john in la, 11-18-2004 04:52:15
If you're using coat hangers on sheet metal, that pretty much sums up the problem. You need thin thin rod and small small tip and enough pressure to keep the heat and flame outside of the tip. Experiencing any warping on those fenders by any chance?
john in la
11-19-2004 04:40:16
 Re: Torch popping in reply to JHesler, 11-18-2004 17:02:38
Well I am using brand new rods I got from the welding supply. Some one suggest I use coat hangers so I said I would try that.
A liitle warping in some spots. Figure that is expected.
thurlow
11-17-2004 14:33:22
Sounds to me like your tip is not "seated"; will definitely cause the problem you're describing..... .
JD_IHC
11-17-2004 14:13:11
I think that's detonation inside the tip after the mixing chamber. It's getting too hot in there. Your tip is too close to the weld or you need more flow. I haven't found a tip yet that is small enough to do a good job on sheet metal. They probably exist, I just don't have one. They need to be real small.
Ramrod
11-17-2004 12:06:01
Are your pressures right at the regulators? It sounds like you don't have enough flow at the tip. To light it, I always turn on fuel and light, then turn fuel down until it is almost not smoking, then turn on oxy slowly to get blue cone defined at tip. Go past the 'cone point' and it'll pop.
Ramrod
george md
11-17-2004 11:25:29
John,
The most likely cause of popping is not enough gas flow thru the tip to keep it cool. Use more gas flow or smaller tip .
george
Jim Broughton
11-17-2004 16:10:25
 Re: Torch popping in reply to george md, 11-17-2004 11:25:29
John: Increase your gas flow through the tip, just a little to keep tip cool, hold tip slightly "up" from normal acetylene welding and (you'll think I'm crazy) swap your welding rod to good old-fashioned wire coat-hangers if you are welding light sheet-metal !! Try it !! You'll be amazed at how much better weld you get on sheet metal. LOL...Jim
