Tool Talk Discussion Forum
water softener septic tank?
brian 1
11-16-2004 07:44:07
Have heard that certain types of softeners shouldn't be used if you have septic tank. True or are they trying to sell me their system?
buickanddeere
11-16-2004 21:53:37
 Re: water softener septic tank? in reply to brian 1, 11-16-2004 07:44:07
The ground around the weeping bed isn't wet and stinking now. Ran the washing machine and water softener drine output to the permitor drain instead of killing the septic system. Wish there was a way to route the bathtubs and bathroom sinks out there too.
rad
11-16-2004 17:21:02
Only a problem if you feed the brine regeneration mixture back into the septic. If you put it in a storm drain, no problem. My folks have been using a softener for nearly 50 years and their septic is still going strong.
-rad
Mark - IN.
11-16-2004 15:52:14
I guess it depends whom you talk to. I've always heard that you shouldn't, and can understand why not. Have always had septic tanks, and in the last house, removed the water softener - I hate them to shower in, or for drinking - just hate them in general. But in the new house have one, and lost the arguement.
One thing can do periodically, water softener or not, occasionally add "Ridex" and/or raw beef liver to feed the bacteria. Hey, I hate beef liver too, so in the septic tank it goes (RAW). I've always done quarterly, is not expensive insurance. The truth be told, really shouldn't send soapy water (washing machine, dishwasher, etc) down into it either, but the trap is supposed to catch that. I've run the washing machine out a hose onto the lawn - it has to go somewhere, and since soap emulsifies (breaks down) dirt, may as well put it on the lawn/bushes.
Ramrod
11-16-2004 09:23:40
You don't havta use salt, try Potassium Chloride instead. It's more expensive, but it won't hurt the grass, actually adds potassium, good for it, so you can dump it in the yard. I built a french drain in a trench for my garage deep sink and use that drain for the water softener too.
Ramrod
Midwest redneck
11-16-2004 08:47:34
I have heard too that you cant drain the water softner discharge into a septic tank. But What I did was drain it on a gravel walkway, drains good and helps kill the weeds.
T_Bone
11-16-2004 08:44:46
Hi Brian,
Salt is a purifier, sodium chloride, and it's the chloride salts that effect your septic tank, much like dumping chlorine into the septic, as it stops (kills) the bacteria from doing it's thing.
We use alot of vinegar as that helps the tank contents keep the bacteria active. We use vinegar in our RV tanks for odor control and the first stage of composting. We do not use commerical chemicals.
Salt and vineger will off gass as hydrogen gas. This shouldn't be a problem with a tank of 1000gal or so, or about the size of a septic tank.
I personally would drain any water softner into a settling tank before dumping into my septic tank. This way the heavy salts would collect in the first tank and could be removed (pumped).
T_Bone
KCTractors
11-16-2004 19:36:59
 Question for T-Bone on Vingar in RV Holding Tanks in reply to T_Bone, 11-16-2004 08:44:46
How much vingar do you put in your holding tanks in your RV? Wife says that it would smell like vingar in the rv. I disagree with her.
T_Bone
11-17-2004 06:48:36
 Re: Question for T-Bone on Vingar in RV Holding Ta in reply to KCTractors, 11-16-2004 19:36:59
Hi KC,
I use 1cup/25gal with 2gal water precharge for the black tank and 1cup for a 44gal grey tank (no precharge) when I think about it. Gray water tank only needs it for odor control.
You will smell vinegar when you first dump it in, maybe for 1hr but not strong just a wiff. Sure beats the smell of the blue chemicals tho.
This holds us for 7days without any odor problems but we don't have any gray water running into the black tank. If I have to hold the BT longer then I add 1 more cup of vinegar. About 7days is max without dumping the tank for total odor free.
We boondock camp 100% for 6mths at a time. With this method, TP and solids disolve in 48hrs, ambiment temperature dependant, and this starts the first stage of composting. I use a compost pit, add green pine needles for odor control, leafs and dry grass to each dump cycle. When done with the compost pit then cover with earth.
This method will produce a compost plant food for trees and shrubs with-in 60days for a complete compost cycle.
T_Bone
Wardie Turner
11-16-2004 11:10:37
 Re: water softener septic tank? in reply to T_Bone, 11-16-2004 08:44:46
We have lived in 3 different homes over a 33-year period in Texas - different types of soil. We have always had a water softener, using salt in them. Have always had a septic tank where water went from house. NEVER had one pumped and NEVER had any trouble.
