Kubota problem
Scott N Texas
11-21-2000 08:58:49
I have a kubota L210. I put a new battery on it, had the generator rebuilt and the starter checked out. It still will barely turn over even with a jump start. Any ideas what I can try Next. After I manage to get it started which isnt very often, it runs fine.
Joe Evans
11-21-2000 19:28:14
 Re: kubota problem in reply to Scott N Texas, 11-21-2000 08:58:49
Follow T_Bone's advice. My L275 was real balky cranking on a 5 degree day and I noticed smoke coming from around the battery area. Turned out the stock cables which are the size of your typical computer keyboard cable had a serious case of heat stroke. I got some old 2/0 welding lead and new connectors. No more smoke and no more cranking problems unless, of course, the battery is down.
g
11-21-2000 11:35:06
It could also be a bad starter.
T_Bone
11-21-2000 09:48:02
Hi Scott, sounds like a corrioded battery cable, not the end of the cable but inside of the cable so I would replace the cable if you don't have a VOM to check with. Also ckeck for a bad ground on the tractor side.
T_Bone
