Tool Talk Discussion Forum
Winterizing cordless tools
wilman
11-14-2004 14:34:52
Getting things ready for winter and was wondering if it makes any difference if I keep my cordless drill, saw etc and the rechargeable batteries outside in the unheated garage where it can drop below freezing and stay there for long periods of time (I live in Northeast Iowa) or should I put them in the basement of the house again like I have done since I bought them. What is everyones thoughts?
Thanks
Wil
John *.?-!.* cub owner
11-14-2004 19:01:15
 Re: Winterizing cordless tools in reply to wilman, 11-14-2004 14:34:52
Remember frozen batteries don't work worth a hoot until thawed if you need to use your equipmnet, and also they should be at room temeperature before charging. I have set up a timer that turns on for 30 minutes a day and have an outlet strip plugged into it that all my chargers are connected to. It keeps the batteries at full charge without overcharging them, and they seem to last much longer that way. If I use a battery long enough to run it down I simply move that charger to a hot outlet for the needed time then back to the times strip.
Jon H
11-15-2004 15:39:29
 Re: Winterizing cordless tools in reply to John *.?-!.* cub owner, 11-14-2004 19:01:15
Most ni cad battery makers say not to charge or use a battery if it is below 40 F. I would store them in a warm place. Great tip about connecting all chargers to a power strip with a timer that charges a few min per day. Sounds like the answer to the problem of chargers that do not shut off automatically and tool batteries going dead if not used frequently.
kraigWY
11-14-2004 16:56:38
I keep mine in a unheated garage here, and it gets nippy in Wyoming. Never had a problem. Lot of people store a/b/c batterys in the freezer. They seem to come back to life at room temp.
