Tool Talk Discussion Forum
Dewalt batteries
Jack-Iowa
11-13-2004 19:53:44
Anyone else think it is cheaper to buy a new drill instead of replacing batteries?For the price of 2 batteries you almost have the cost of new and improved drill.
Arizona Bob
11-15-2004 21:06:39
 Re: Dewalt batteries in reply to Jack-Iowa, 11-13-2004 19:53:44
Certainly it is cheaper. Harbor Freight advertises batteries for some of their drills at $7.50 each.
With several corded drills and a couple of bettery drills I still had problems with drilling metal pipes and such along the fence line. Took a 12 volt with worn out batteries and and hooked in 12 feet of 12 gauge wire. Run it off my riding mower battery. Works great.
Bob
Earl S.
11-15-2004 12:42:21
Just type in (Drill Batteries)Hit search. Earl
big jt
11-15-2004 07:22:15
Makita had deals like that. The drill was a bottom end unit. The batteries were their bottom end. Not nearly the good deal that it looked like. Check to make sure you are comparing apples with apples on the batteries.
Batteries for 12v makita can run from $40 to almost $80
JM2CW
jt
ErnieD
11-14-2004 18:00:27
Fix the batteries yourself. Each cell is 1.2 V. The cells fail completely. Disassemble and measure each cell with a DVM. Cut out the bad cells and solder in cells from a donor battery. The straps solder easily. Just watch polarity. You can measure the V of the whole battery and tell how many good cells there are, just note the V from 14.4 or whatever and divide by 1.2.
Mike (il)
11-14-2004 17:27:46
I think it is a smarter way to go. I just did this myself. even if you buy the batteries it might not take care of the problem completely. for another $40 or $50 you can get a brand new drill. i just bought a 14.4 xrp series that shows it has more torque than the standard 18 volt for $199
Leland
11-14-2004 01:28:32
If you just buy new drill kit then you always have a spare drill. that comes in handy once in a while.
Jack-Iowa
11-14-2004 07:51:41
 Re: Dewalt batteries in reply to Leland, 11-14-2004 01:28:32
yes but when there are 2 different volt batteries back to being darned.
Leland
11-14-2004 19:16:53
 Re: Dewalt batteries in reply to Jack-Iowa, 11-14-2004 07:51:41
I've always been lucky then,but Menards is about the cheapest on replacment batteries that I have found and they are shipped to your door.
