Tool Talk Discussion Forum
3 phase converter
Vince
11-12-2004 20:39:16
I want to make a 3 phase converter out of a 7hp to 10hp 3 phase moter if you know how send me a drawing please keep it as simple as you can [email protected] Thanks Vince
Big Jake
11-15-2004 07:22:37
 Re: 3 phase converter in reply to Vince, 11-12-2004 20:39:16
Link
buickanddeere
11-14-2004 08:24:22
Some applications are better served by feeding single phase into a VFD ( electronic variable frequency drive) that provides 3 phase out. Worth a thought.
JMS/MN
11-13-2004 17:26:37
On single phase 240V you have Line 1 and Line 2. Hook them to two wires coming out of your 3phase motor. Also hook them to Line 1 and Line 2 of your load. Hook the third line from your 3 phase motor to Line 3 of your load. Belt up a single phase motor to your 3 phase motor to start it spinning. Use a hinge or belt tightener so you can shut off the single phase motor after the 3 phase is spinning. The spinning 3 phase motor generates the third leg that you need to run your 3 phase load. Capacitors on a phase converter do the same job as your single phase motor does in this setup. (Rotary phase converter).
DaveInMId
11-13-2004 02:43:23
There's a whole section of this website devoted to phase converters: www.practicalmachinist.com
chris mf 135
11-14-2004 07:56:43
 Re: 3 phase converter in reply to DaveInMId, 11-13-2004 02:43:23
here are two links on building them, they are the best i"ve seen and will work.
Link
Link
hope these help
