Tool Talk Discussion Forum
Webster Compressor
Rowan Smith
11-12-2004 12:37:19
I recently was given a functional 80 gallon 6.5 hp Webster Compressor. It worked great, was in good shape, and looked solidly built.
Some people were transporting it for me, and they dropped it. Never send a boy to do a man's job. The only damage it sustained was on the large pump pulley. However, the damage was severe. It smashed the snout off the crank.
Aside from the beating I should have laid out on the fellow who lifted the round compressor with his forklift and it fell over (top heavy - surprise!), I also need help with parts.
I have spoken to a machine shop. They have said that they would like to pull the crankshaft out, machine the broken snout as well as the part remaining so they are perfectly flat. Then, drill and tap a hole and run some ready rod through the centre of the snount and crank. Next, they bevel cut around the now machined flat break and re-weld it together using multiple passes. In theory this sounds strong enough for my purposes.
However, I know Webster went out of business back in the 80's and I heard that the employees bought all the old stock. I also heard they still make parts for these thinks, EXCEPT CRANKSHAFTS, as the cost on a small run of such an item is prohibitive.
Does anyone know of a dealer that can get parts? I would really like an online contact if possible. Are they marketed under a new name? One fellow mentioned the word "Econoline" several times but was so anxious to get off the phone I didn't get it out of him what he meant.
Additional Information About my Compressor:
Model 651 2 (the 651 is in black. The 2 is not)
Compressor Serial #20365
Pump Serial #654991
In short:
1. Are parts still made for these? 2. What about crank-shafts?
3. Is the proposed repair to reattach the snout sound strong enough? 4. If not, any other suggestions?
I know there are few guys out there that know a lot about these Webster compressors. I have seen some darn good informative posts already, but nothing that can speak directly to my question.
As a general rule, are these compressors good?
Thanks for you help.
Rowan
Roger P.
11-12-2004 13:31:20
 Re: Webster Compressor in reply to Rowan Smith, 11-12-2004 12:37:19
Yes, they are very good compressors, with a few exceptions.
Webster was a maker of fine industrial compressors and spray paint equipment, based in London, Ontario. They indeed went out of business around 1988. Employees bought up the remaining stock, of which there was an amazing amount. I imagine they got undercut by foreign manufacturers, and having DeVilbiss-DeVair down the road to compete with was no walk in the park. The guy who ran the show passed away a few years ago. His daughter (I think) took over for a bit, but she too has passed away. I believe, but I am not sure, that Compresseurs Quebec has taken over the Webster parts business. I can find out exactly, but it will be a few days. The shop I used to work at here in Ottawa got a notice about this a few months ago. It is a company in Quebec, of that I am sure.
You have a Webster Model 65 (Hint: The first two numbers in the pump serial number is the pump model number when talking about a Webster pump). You're right, a new crankshaft will cost you about $500 CAN, since they were not put back into production like the rest of the machine. To be honest, there aren't many people who will put such an expensive piece into a compressor that is at least 16 years old now (though they are certainly worth rebuilding), so it makes no sense to stock them. I know my former boss has a pristine Model 65 in stock, but I doubt he will sell it for parts, as the pump is worth quite a bit as a drop-in service exchange pump. I know of at least one guy here in Ottawa whose 65 has met the same fate as yours. Webster cranks are a bit brittle, and rarely survive the whack they get when tipped over. Always lift a reciprocating compressor by putting the forks as close together as possible and sliding them in under the saddle. The crankshaft is cast iron (I think) so the welders on this site would be able to tell you if they think it would be a strong enough fix (I believe it would be). You do not mention where you are located. When I hear Webster, I automatically think Canada, so if you are located near a Princess Auto, you should maybe check out the 5hp cast-iron pump they have on offer. Right now, they are on sale for around $399 CAN, which is probably less than the repair you are considering. You would have the benefit of a new pump. Sure, it's not quite the same quality, but it's not exactly crap either, and might make more economic sense. Go to princessauto.com and download their flyer (pdf). this will tell you if it is still on special.
Rowan Smith
11-12-2004 16:10:16
 Re: Webster Compressor in reply to Roger P., 11-12-2004 13:31:20
Thanks for that info. You know far more about these compressors than is healthy!
Thankfully, my close friend is a damn fine machinist and he will do the repairs for free. I would really like to rebuild that unit if possible as it seems built very solidly - a rarity in this day and age.
Yes, I am in Canada. In the greater Vancouver area. I don't have much experience with machinery repairs, so if you know of a good shop that would be nice. I have spoken to a few places and they all have old-guys running a disgusting shop full of what appear to be crack addicts. That is not to say they don't do damn fine work, but appearances often count for something.
I imagine places like that would have, or able to get, gasket sets? Or must I manufacture my own gaskets?
Thanks again.
Roger P.
11-12-2004 20:55:04
 Re: Webster Compressor in reply to Rowan Smith, 11-12-2004 16:10:16
Gasket sets are still available, as are rings, valve plates and springs. I believe rods are also still available. Model 65's used bronze rods and tended to stretch out the wrist pin bore until it was oblong, so make sure you check this, and get your machinist buddy to bore them out and push in some bronze bushings to restore proper fit if necessary. If the big ends are slack, you can laps the ends of the connecting rods and caps to tighten up the clearances a bit. A proper disassembly is really necessary before you can judge what you will need. Might turn out that the cylinders are scored up, in which case I'd throw on the Princess Auto job and call it a day. It is a really top notch compressor though. I was lucky to snag one from an old fire station for my brother in law in Edmonton before I moved back east.
Your remark about the disgusting shops and the crack addicts seems oddly familiar.....
David with Webster
01-29-2005 17:24:38
 Re: Webster Compressor in reply to Roger P., 11-12-2004 20:55:04
Roger,
Any information on where to obtain rings for a Webster 35-4163? the diameter of piston is approx. 5cm. Please any help would be appreciated. Location is Ontario Canada.
Thanks
David
