The sequence you propose is not quite right. Your objective is to get the water out of the tank, in order to restore draw-down volume, not to precharge a tank that is almost full of water, which won't do anything for you. Shut the electrical power to the pump off. Turn on a faucet until the pressure drops to zero. Turn off the valve that should be between the outflow of the tank and the rest of the house. Connect a hose to the drain valve that should be below the bottom of the tank. Put the other end where the water can drain away without damage. Open the drain valve. Use your compressed air hose at the fitting on top to help push the water out of the tank and thence out the drain valve. You want to end up with the tank almost empty of water. You can precharge the tank if you want. But without a bladder the air will tend to dissolve into the water relatively quickly. I think the normal practice with non-bladder tanks is to drain the tank completely, then let it fill up with water starting from zero pressure. You will end up with the tank 2/3 full of water at the cut-out pressure. Turn the drain valve off, turn the pump power back on, turn the house water back on. Open a tap somewhere. Let the pressure drop until the pump comes on. Time how long it runs. A 3/4 horsepower pump should run for at least one minute each time it starts. That is the main purpose of the pressure tank. 40/60 is a good choice to get minimal fluctuations in the house. It is more demanding on your pump, well piping, and pressure tank. It will get to be tough to get one minute run-times at 40/60 with a non-bladder tank due to the air getting dissolved in the water. The higher the working pressure, the faster this happens. On my previous house, I used the biggest bladder tank that Home Depot sells and got about a 3 minute run time with a 3/4 horsepower pump and 40/60 settings. This worked fairly well. The current house uses a 3HP 3 phase motor and VFD drive on the pump with the same size pressure tank as the old house. The 1 second frequency ramp afforded by the VFD eliminates the starting inrush current and thus the need for two minute run times. It would have taken 3 of these big tanks without the VFD.
