Tool Talk Discussion Forum
What do I need to do basic welding?
Rod in S.F. Ont
11-10-2004 15:38:04
I do a lot of woodwork, but have virtually no tools for working with metal. Moving to the country will involved much more metalworking than before.
How many amps 220 do I need for a welder? What should I get? Cutoff saw -- generic brand 12" o.k? Safety equipment? Does this stuff come as a kit?
First project would be a 3pt hitch platform for hauling big blocks and stuff around.
Thanks,
Rod
john908
11-11-2004 15:58:29
 Re: What do I need to do basic welding? in reply to Rod in S.F. Ontario, Cana, 11-10-2004 15:38:04
Go with the 50amp circut,220 volt.
TimV
11-10-2004 19:15:58
Rod: Mark"s advice about getting an oxy/acetylene torch is good--they"re much more versatile than an arc welder. However, they won"t work for sticking large pieces of metal together. A good 220 MIG will serve 90% of your needs, and they"re much easier to learn on than a stick welder. I"m making the assumption that you don"t have much welding experience (If I"m wrong, no disrespect intended) and thus figure you"d be better served by a MIG"s simplicity than a stick welder"s versatility. Stick with the 3 major brands (Lincoln, Miller, or Hobart)--you"ll get a better welder and better support as well, for not much more money. Many welding supply houses offer a "starter package"--for instance, I bought my Hobart Handler 135 (110-volt MIG) complete with a face mask, gloves, full gas bottle, and a pound of both flux-cored and solid wire. I was ready to start welding within 10 minutes of getting the welder home. If you"re looking for a good "starter" stick welder, the Lincoln AC225 is pretty much the gold standard--thousands and thousands have been made, they"re nearly bulletproof, and they"re often availible for $100 (US) or less used but perfectly serviceable.
MarkB_MI
11-10-2004 18:38:06
First, get a good acetylene torch set if you don't already have one. It will get a lot more use than the welder, and you can use it for light welding in a pinch.
Most of the smaller 220V MIG welders will work on 20 amps, but if I were you I'd go ahead and bump up your 220V service to 50 amps. That way you'll be OK with whatever welder you end up buying. Use the 20 amp outlet for your air compressor.
Around here, TSC sells 3-point platforms for around 40 bucks; you can't hardly buy the materials for that.
11-10-2004 17:44:30
And I just had a panel put into the old garage, but only for 20 amps, 220.
So would a TIG welder stick 3/16" angle and plate together?
How many amps would I actually have to have to make a Lincoln-type welder do the job? Would 30 work?
I don't plan to do much welding, but don't want to be handcuffed by the inability to stick things together.
Thanks for the advice, so far.
Chester
11-11-2004 11:01:58
 Re: What do I need to do basic welding? in reply to Rod in S.F. Ontario, Cana, 11-10-2004 17:44:30
third party image
My present shop came with a 30 Amp/220V service and allows my Lincoln 225 buzz box to burn 3/32" dia rods at 75/90 Amp output without blowing a fuse. But, that is the fuse"s limit so you are pretty much limited to 1/4" material. Also have an oxy-acetylene system that can be seen in the link below:
Chester
11-11-2004 11:06:14
 Re: What do I need to do basic welding? in reply to Chester, 11-11-2004 11:01:58
Here's the link:
http://community.webshots.com/album/183972727BaCdUl
jniolon
11-10-2004 17:39:16
Your final decision on a welder should depend on its intended use... If you plan on doing primarily heavy welding (1/4" and up...farm equipment, heavy plate and angle iron) then a stick welder will serve you well, although a hi amp wire machine will work also. You"re looking at the 200 amp and up work there
If you plan on light gauge projects, sheet metal work, body repair then i"d say a mig machine would serve you better. Light gauge tubing, 1/8" plate... Body repair... That type of thing.. Thickenss will also determine the amperage you need.. For all light gauge work like body sheet metal and such you can do with a 110 volt machine 90-110 amp welding current.
For 1/4" and down anything between a 100 - 200 amp machine will serve you well. Heavy stuff... 200 or better..
My assesment of harbor.freight�. cheap import junk.. Although you can get good deals on name brand tools sometimes, they sell basically low quality tools... Stick with a name brand... Miller, hobart, lincoln... You can always get replacement parts...even on weekends and they have good service reps...
I have a hobart "suitcase" welder, 100 amp 110 volt for light stuff and it does a great job using either gas or flux core. For larger material i have a millermatic 200. A 200 amp 220 volt machine that will handle anything else i tend to stick together.. I normally run both on gmaw... Only using flux core for outside windy conditions. (the wind blows the shielding gas away). Flux core wire needs more clean up than gmaw (gas metal arc welding...gas shielded) it tends to splatter more. I also have a lincoln 225 amp ac/dc stick welder that i haven"t turned on for several years since i bought the wire machines..
I think wire welding is a lot easier to master than stick and much easier to see and control your weld puddle.
I bought both of my machines used.. From welding houses that had leased them out then refurb"d them and sold them... You can get some really good deals if you"re patient (?). Check with some of the supply houses and watch the "machinery and equipment" column in the classifieds.
Anything over 175 amps will probably require 220 volt service so plan on that expense also (if you can"t do it yourself.
Safety equipment.. A good helmet with the proper shield.. You can get away with lighter gloves with wire welders... But with stick, get some good heavy welding gloves. A fire extinguisher close by and readily accessable is a must as well as a bucket of water for cooling your welds. Clamps, pliers, vice grips and a bfh are almost a necessity. Wear long sleeves and long pants that are not tucked into your boots.. No sneekers... Hot metal goes thru them like...well hot metal !! Hope that helps.. John
Harvey O'TOOLE
11-10-2004 17:19:05
Rod You may also consider a Mig welder, it will cost you a little more but easier to use and some of the lower models run on 110 volts.
Canadian Tire offers a package deal which includes a mask, hammer and I think gloves, for around $600. (They usually go on sale). This type welder would probable suit your needs.
Harvey
old
11-10-2004 16:42:43
A good old lincoln buzz box needs 220 volts and a 50 amp bracker. Go with a 14 inch cut off saw and at times thats to small. Helmet for the welder and safty glasses for the saw. Gloves are nice to have also and welding chaps but you can get by with out the gloves and chaps but be careful if you go that way things get very hot.
Big Jim
11-10-2004 21:36:55
 Re: What do I need to do basic welding? in reply to old, 11-10-2004 16:42:43
I have a 12 inch saw. It has served me pretty well but it is often difficult to find blades. 14 is the standard for portable saws and everybody has 14 inch blades.
