Tool Talk Discussion Forum
OT: Sleve removal
nwb
11-10-2004 15:24:49
I have a project at work that has me stumped. We need to remove a 2" brass and graphite bushing/bearing sleve from a tube. The sleve is 5" long and the tube is 18" long. The sleve is pressed into the tube and the I.D. of the tube is the same as the sleve. (When the sleve is in place the I.D. is the same throughout the tube.) The problem is we cannot get anything in the tube to drive the sleve out, or pull it out. I'm in need of suggestions if anyone can help. Thank-you.
nwb
11-11-2004 15:14:59
 Re: OT: Sleve removal in reply to nwb, 11-10-2004 15:24:49
Thanks for the ideas. I tapped two holes, ran them through a bar of steel and pulled it out. Thanks for the help. Sometimes I get brain locked and need some outside help.
Mike M
11-11-2004 06:08:03
I have removed many bushings even from blind holes with a punch with the end reground like a U leaving sharp edges you can cut right down through the edge of a bushing.
Davis In SC
11-10-2004 18:52:32
I assume you mean bushing is pressed up to a blind shoulder. If it is something you can put in a mill or lathe... bore it . If so, once you make a few passes, it will probably come out easily. Or tap it , make a stud to thread in & use a slide hammer to extract it. There are lots of ways to skin a cat.
Jet9N
11-10-2004 17:48:32
I've done that thing a time or two. Take piece of
flat steel about half the width of the O. D. of the bushing. Cut the length to the O. D.of the bushing. Grind a radius on the ends so it would
fit inside the tube. Then grind a "back" angle on
the radius ends so it can be "tipped" in the tube.
Put this in the tube endways and then tip it crossways. This will give you a push block on the
end of the bushing. (Be sure to tip it so the long side of the pusher is toward to bushing).
HTH
Jet
Jet9N
11-10-2004 17:51:57
 Re: OT: Sleve removal in reply to Jet9N, 11-10-2004 17:48:32
The above assumes you can push from the other end.
If not, tap a hole in the middle of the block you
made and use a piece of threaded rod to pull it
out.
Jet
Vern-MI
11-10-2004 15:50:45
Do you need to save the bushing that is inside the sleeve? If not heat the assembly in an oven until the thermal coefficient of expansion of the aluminum allows the bushing to fall out of the sleeve.
