Tool Talk Discussion Forum
Stove Pipe?
Lee Hartsell
11-09-2004 18:44:19
Maybe not exactly a tool but hoping for some ensite. Last year I put a wood heater in my shop, went to Lowes for the smoke pipe. With winter on the way I had a look at it the other day and in a years time it is rotted and about to fall apart. Is there a really good grade of stove pipe. I haven't had anyluck at the normal suppliers. Any help would be appreciated.
T_Bone
11-10-2004 23:12:00
 Re: Stove Pipe? in reply to Lee Hartsell, 11-09-2004 18:44:19
Hi Lee,
Most likely you bought 28ga vent pipe at Lowes rated for low tempertaures (less than 200�), and not stove pipe rated for chimeny's that's made for wood stoves or fuel oils.
With the new EPA regulations on wood stoves most mfg's are use a after burner plate in the top of the wood stove before the vent exit.
This causes the wood smoke to recirculate from the top of the burner chamber to the bottom to reburn the gasses thus exracting more heat and also lowers the stack temperature.
With lower stack temperatures also comes a lower dew point inside the stack causing moister.
Water and wood ash make lye.
Since the stack contains wood ash along with moister we now have lye on the stack walls thus causing the excessive corrosion problem.
The thicker vent pipe rated for wood stoves will last longer than what you used. How long is hard to say as I don't know your area.
If the chimeny is enclosed then you must use SS 304 triple wall for this very reason.
Never run a single wall chimney thru any type of roofing including metal. Metal roofing requires a doubble wall thimble 6" below the rafter to 12" above the roof deck for a good reason, too keep the building from burning OR starting any outside fires.
T_Bone
Georgia Boy
11-10-2004 18:29:07
I had the same problem until I installed the heavy gauge stove pipe. It is several times thicker than the cheapo stuff. It has lasted 20 years so far, but I might replace it soon with a masonary chimney.
Leland
11-10-2004 16:29:04
We used a piece of 6in steel pipe with 1/4 in walls,never any worries and easy to clean just smack with large hammer
Dennis in Wis
11-10-2004 06:05:36
if you can use single wall pipe go to metal shop and have them roll and weld a stainles steel one up for you *** it is going to cost *** had mine in for over 15 years now and no trouble yet *** I went through a metal roof so single wall pipe was ok for me but if your going through wood you might have to put a short piece of triple wall or also called all fuel in good luck
jdemaris
11-10-2004 05:57:12
You didn't mention what kind of heater you're using. If it's wood, 24 gauge black pipe will give you a few years, but if you're burning oil - forget it. One year life-span if you're lucky. The acids in oil burner fumes need galvanized pipe. Better yet, if it's just an LP or Oil heater, you can buy single wall stainless steel pipe. If it's a solid fuel, e.g. wood or coal, you should get pipe rated for it. The other guy mentioned triple-wall, which is fine except triple wall is almost obsolete in this country. What has taken it's place is double wall stainless with insulation. It keeps the inside pipe warmer than the old triple wall and thus stays cleaner. Simson Duravent, Metalspestos, etc. sell it. If you want the absolute safest stainless smoke pipe, the stuff sold in the Canadian market is better than in the U.S. That's because their standards are stricter, especially for durability in a chimeny fire. Selkirk Metalspestos sells a United States version of pipe, and a Canadian version. With a litte work you can buy much better Canadian version for around the same price - but some dealer's, if not most, won't try to get it for you. Candian tests for chimney fires with the Selkirk Metalspestos CF Sentinal pipe are CAN/ULC-S629. U.S. test is US testing: 103 HT standard, UL File #MH7399. I found a dealer in Northern NY (along the Canadian border) that does.
Canadian test explained: CAN/ULC-S629 for 650�C factory-Built Chimneys. The temperatures used in this
standard are: 1200�F (650�C) continuous (normal firing), 1700�F (925�C) one hour
(overfiring) and 2100�F (1150�C) half-hour (creosote burn out) three times. United States test: US testing: 103 HT standard, UL File #MH7399. Designed for normal continuous
operation at 1000� F flue gas temperatures, DuraTech 6" and 8" diameters have been
subjected to rigorous and stringent UL testing including one hour at 1400� F, plus three
ten-minute chimney fire tests at 2100� F.
Robert in W. Mi.
11-12-2004 18:29:12
 Re: Stove Pipe? in reply to jdemaris, 11-10-2004 05:57:12
I've have the "Canadian" stuff installed for some time now, and i bought it all from Menards.
Robert
FarmerDave
11-10-2004 12:00:53
Nice post. With NAFTA, UPS and the web one oughta be able to get that Canadian pipe.
We have single wa11 24 gauge pipe in a couple buildings. It's a heat radiator. If you get the insulated stuff more heat goes up the flue.
The by-products of combustion are hard on steel. If you clean your flue at the end of heating season, I suspect it will last longer.
I have 24 gauge black pipe at least six years old. I recently have changed the two pieces closest to the stove.
HTH
jdemaris
11-12-2004 18:45:14
 Re: Stove Pipe? in reply to FarmerDave, 11-10-2004 12:00:53
I was only referring to pipe that runs outdoors. I've got 24 gauge black pipe in my house that's 15 years old and it's still fine. Got a woodstove downstairs and the black-pipe chimney runs up through the ceiling, to the next level, through a bedroom, and finally hooks to a brick and tile chimney that starts at the roof level. Our house was built ca. 1820 and has three chimneys that all start at the roof level with a "chimney-closet" underneath them. They used to make me nervous, seems like a lot of weight to have no support underneath except some wood and plaster.
Nolan
11-10-2004 03:32:18
Did you run this pipe without a rain cap? My black pipe lasts for years with a rain cap on top.
TimV
11-09-2004 18:49:58
Lee: What you need is Triple Wall pipe. It"s usually stainless steel and will last much longer than regular stove pipe, in addition to contributing to a much safer installation. The downside is that it"s VERY expensive--around $50- $75 per 3-foot section the last time I priced it.
walt
11-09-2004 19:13:40
 Re: Stove Pipe? in reply to TimV, 11-09-2004 18:49:58
Actually triple wall is old tech. Newer stuff is 2100 degree pipe. But also expensive and heavy.
Mike M
11-09-2004 18:46:05
Pay the extra money and buy stainless steel pipe,end of problems.
