Tool Talk Discussion Forum
Your opinion on a outdoor wood furnace please.
Brian in NY
11-08-2004 05:39:25
My cousin has a nice used outdoor wood furnace, it is stainless steel on the outside, don't know what brand, etc. yet. He has to part company with it due to a physical ailment (can't get outside to fire stove or haul wood) and is willing to give it to me. I would like to have it to heat part of my pole barn....my question is this....what is involved in hooking up this unit to heat. Doesn't have to be efficient really...I get my wood for free. Want to go the simplest, cheapest route while being safe. Thanks in advance for the help.
Nolan
11-10-2004 03:31:21
 Re: Your opinion on a outdoor wood furnace please. in reply to Brian in NY, 11-08-2004 05:39:25
Something to consider. These units are generally stinky smoky pigs, and often times are cracked down upon by your local government. Not sure where you are in New York state, but you may find yourself served with an order to shut the unit down and a fine. Do a little checking before you install this unit.
Midwest redneck
11-09-2004 15:22:13
Take the stove even if you dont use it. Those fuel prices are real high, as if you need for me to tell ya. I know of a few folks who are looking at getting a wood stove to lower that fuel bill and I know of one guy who heats only with wood, about 10 full cords per year. I get the stove piped in by a professional and then use a fan to move the heat around.
MapleStone
11-08-2004 10:29:59
You said cheap so here's my "cheap" solution.
My uncle built his own wood boiler and used an old truck rad and fan to heat his shop.
He simply built a stand for the rad, mounted a shaft with the fan on it behind the rad, mounted a belt pully to the shaft and used a small electric motor to drive the fan via the belt.
Probably not the most efficient set up but it was cheaper than buying a premade unit.
BTW, I laughed when you said "get my wood for free". Is any wood actually free? You probably own a chainsaw plus there's your time to cut and split. But I know what you mean, time is free, oil is not!
Talk to ya later.
John *.?-!.* cub owner
11-08-2004 06:27:50
Your description sounds like it might be a Hardy. If it is they use water lines from the furnace to the heated building to transfer heat. Will need an air handler and water coil in the shop. One note, if it is this type, once it is installed it must be fired anytime the weather is cold. they use straight water, no antifreeze, and will freeze if not heating. Also the water type use about twice as much wood as one that is adjacent or inside and only uses air.
SproutW
11-10-2004 01:54:23
 Re: Your opinion on a outdoor wood furnace please. in reply to John *.?-!.* cub owner, 11-08-2004 06:27:50
I own a Hardy wood burner and was wondering why antifreeze could not be used. I use it all winter long but was under the impression when I bought it I could charge the system in antifreeze instead of water. I love the heat and it is very efficient. The unit has a fan in the fire box that turns on when the house needs heat. When the house doesn"t need heat the fan turns off and the fire just smolders. Thus the Hardy wood burner uses less wood. I had a standard woodburner that use to be in the basement and used much more wood then the Hardy uses. It"s amazing to look out the window and see six inches of snow on top of the Hardy while smoke is pouring out of the smoke stack. They are insulated well and you never have to clean the smoke stack or worry about fires. I love mine and if you have one it"s a great wood burner to have. However, the unit does use an A coil similar to an airconditioner and piping. If you don"t have these items the start up cost will be alittle pricey. The only thing better is a good corn burner. My body is starting to feel the effects of many years of cutting and chopping wood. If you don"t wnat it let someone know and sell it. I"m looking for another one to heat my new shop building.
buickanddeere
11-08-2004 11:25:14
The efficiency gets better if it's used harder to heat a couple of buildings and a garage. Most stoves get filled full once a day and just smoulder. The flammable gasses get cooked off and get stuck in the chimney as creosote or up the stack. A bright clean burring fire is using burning the wood gasses and the carbon/coals. Can be worth it just to keep the smoke, dirt and bugs out of the house. Sometimes drops the insurance rates by getting the burning process transfered outside.
paul
11-08-2004 08:59:20
Pretty much what I was going to say - no point repeating it, eh? :)
He'll either need the water-to-air heat exchanger, or some form of water radiation - in floor ($$$), radient tubes, radiators, etc.
--->Paul
Brian in NY
11-10-2004 11:25:29
 Re: Your opinion on a outdoor wood furnace please. in reply to paul, 11-08-2004 08:59:20
Well guys, thanks for all the replies. A little more info from this end. I live in extreme SW NY state. It is VERY rural out here, and heating with wood is not only accepted but very popular. HECK, the town barn offices are heated with an outdoor furnace. The wood is so plentiful around here because there is an Amish sawmill on just about every corner and the by-product of their industry is perfect for burning. All oak, cherry or maple slab wood, usually free for the taking. It is already dried/cured and burns like the devil. You use a little more because it is cut thin, but for free I will live with it. Have been using this stuff for years and have been just as happy with it as the tops I cut and split myself. There are at least 6 of these sawmills within 1 mile from my house, so it is convenient too. I think I will grab the stove up, even if I just hold on to it for a bit. Seems like it has some value; and who knows what I could use it for. Thanks again and y'all stay warm.
Redd
11-11-2004 11:30:00
 Re: Your opinion on a outdoor wood furnace please. in reply to Brian in NY, 11-10-2004 11:25:29
Her in Mich my brother inlaw got one while remodeling his house from about 700 sq ft ot about 2,400. During construction he put a nice Radiator from a stationary diesel in the house and a regular heater in the garage. it works great and when done will be piped to the radiant floor heat. He only used about 12 face cords. In the fall and spring he can throw whatever little debris on hand in it.
