Tool Talk Discussion Forum
Sleeve Puller
SproutW
11-07-2004 14:59:22
Looking to buy a sleeve puller and need some advise from you guys out there. I've used sleeve pullers in the past but know little about them. I'm tired of renting and I'm sure the costs in the long run it will be cheaper for me to just buy the darn thing. I'm sure the most economical approach is to just buy a used one. However with that said, if a new one is not that overly expensive I would soon just buy new. My question is this, what would a sleeve puller cost me new or used? What brands/types of sleeve pullers should I look for and run from. Thanks guys.
Dell (WA)
11-08-2004 01:28:09
 Re: Sleeve Puller in reply to SproutW, 11-07-2004 14:59:22
Sprout..... ...run a couple of arc-weld beads down the full length of the sleeve you are removing (don't weld thru). The arc-weld will cool and actually SHRINK your sleeve effective OD and will be very eazy to remove.
For re-installation of a NEW SLEEVE, I like to make a "DRY-ICE" installation tool outta couple pieces of jigsaw cut round wood plugs (doesn't haffta be precision) and a long length of reddi-thread rod and some nutts. Then gitt some chunks of dry-ice (yellow pages) and fill up the sleeve beween the wood plugs with buncha small chunks of dry-ice and let the minus 100F dry-ice shrink your sleeve and just sticker into the cylinder. NO HAMMERING or PRESSES required, just leather insulated gloves. Simple, eh? ..... .....Dell
SproutW
11-08-2004 15:29:45
 Re: Sleeve Puller in reply to Dell (WA), 11-08-2004 01:28:09
Pretty amazing Dell, never would have thought that one up. It sounds like that process would work great for dry sleeves. Especially the sleeves that are junk. I might try that on my old frozen up Farmall M.
Unimog
11-07-2004 20:04:08
Ed Davis of E+K Ag Products makes a nice puller
for about $150 to 200. He will make up the size
you need if it is not included in the set after
you buy it. Charges about $10 for extra pulling
plates. Phone is 1-417=679-3530 and email is
[email protected] Info should be the same, but it
two years old.
SproutW
11-08-2004 15:30:46
 Re: Sleeve Puller in reply to Unimog, 11-07-2004 20:04:08
Unimog,
I sent the individual an email yesterday and I'm just waiting for a reply. Thanks for the information.
SproutW
kyhayman
11-07-2004 16:28:44
Local Auto Valu store just priced me one for $500US for and S & K brand.
