Repairing Holes in Metal Parts
Bob A
11-17-2000 18:04:51
I am currently restoring a John Deere 420c. There are many metal parts where the holes have been worn to the point where thay are oblong or on some cases twice the size of the original hole. What is the best procedure for repairing the holes? I was going to weld in a piece of metal and drill it out to the original size. The metal thickness on most of the parts is 1/8 inch or better.
Thanks
Bob A.
T_Bone
11-18-2000 17:21:02
 Re: Repairing Holes in Metal Parts in reply to Bob A, 11-17-2000 18:04:51
Hi Bob, By the time the metal has elongated a hole the metal has fatigued and will resplit again if not braze welded. Heating a large area will stress releive the area and thats what brazing does, heat a large area coolling slowley. Welding with Mig or Stick will let the reparied weld area crack within a short time.
Even using a fill piece without brazing will have the same effect as the stress will travel a long distance. Use good old baling wire for a filler rod.
T_Bone
Franz
11-18-2000 18:57:29
 Re: Re: Repairing Holes in Metal Parts in reply to T_Bone, 11-18-2000 17:21:02
Back it up with a firebrick, place a carbon button the size of the hole you want to wind up with exactly where you want the hole to be, and weld to it with a MIG machine. If you don't have MIG, og with TIG. All else fails, use 7018 rod in a stinger.
Greg
11-17-2000 18:33:34
One way I fill these types of holes is to clamp a solid copper backing plate to weld against. The weldment will not adhere to the copper. The weldment is hard to drill, but makes a nice looking and strong repair. I generally will use a die grinder with a carbide burr if I need to size up the holes.
The tabs on large fuses may be a good source for smaller copper plates.
HTH
Bill D
11-18-2000 05:55:18
 Re: Re: Repairing Holes in Metal Parts in reply to Greg, 11-17-2000 18:33:34
There should be a way to temper the weld area maybe Steve will sign on and give his usual good advise
Greg
11-18-2000 06:42:14
 Re: Re: Re: Repairing Holes in Metal Parts in reply to Bill D, 11-18-2000 05:55:18
Or Fred OH, as this is MIG country. *grin*
Fred OH
11-20-2000 09:45:12
 Re: Re: Re: Re: Repairing Holes in Metal Parts in reply to Greg, 11-18-2000 06:42:14
Greg, think I'll just get in here and tell you that I've done a blue million of 'em and never owned a mig welder. (grin) As far as I'm concerned, the right ways have been given but the mig would be my last choice as it is the most expensive way to weld. If you're a real good welder, the only thing you generally need a mig rig for is thin stuff like body work and production work. There, I kicked them again so you grin. I generally turn a piece of carbon in the lathe a few thousandths of an inch smaller than original hole but with a head left on it to use as a backup. Push it up against the unworn part and fill the gap with brass. If it's a clevis type end, do the same thing with the other side and run a reamer through it to bring back to original size. If it doesn't have to look original, sometimes I saw off each side and weld on flat iron and then drill to size and it's like new, done quicker and cheaper. Now if Steve gets in here, you just remember that JB Weld won't work on this one. (grin again) Happy Turkey Day (or do mig welders eat that 'ol dead bird)? L8R----Fred OH
BFO
11-20-2000 17:07:49
 Re: Re: Re: Re: Re: Repairing Holes in Metal Parts in reply to Fred OH, 11-20-2000 09:45:12
Naw, mig welders only eat TV dinners, push a button and it's done ;-)
welder Brian
11-19-2000 19:44:58
Re: elongated holes should be ground out,welded up and drilled out or ground out with what ever works. lets remember it's not a NASA satalite
fredb
11-20-2000 09:53:36
 Re: Re: Re: Re: Re: Repairing Holes in Metal Parts in reply to welder Brian, 11-19-2000 19:44:58
You must be one of those people who lets everyone know you think you are a welder by calling yourself that.
It's not rocket science, but you need to do the job correctly so that you won't have a wreck somewhere down the line.
Greg had a good point about using copper behind the weld to keep it from sticking. Good way to do it.
Maybe I'm overreacting, but when I see someone call himself a profession, such as welder, it makes me wonder.
SLAG
11-20-2000 21:07:18
 Re: Re: Re: Re: Re: Re: Repairing Holes in Metal Parts in reply to fredb, 11-20-2000 09:53:36
Hey fred cool it! you sound like you like to insult people, go away! besides he's right it aint a rocket ship
