Tool Talk Discussion Forum
Stihl 026
opus
11-07-2004 08:28:40
I need a piston and a cylinder for this. I am not wanting to put another $200 into it though. Has anyone ever honed and stuck a new set of rings on a chainsaw? I havent looked at depth to how bad they currently are, will do a little later.
opus
11-08-2004 08:28:18
 Re: Stihl 026 in reply to opus, 11-07-2004 08:28:40
Hmmm....3rd time replying to this post and no post.
Anyways, there is no way I am going to be able to hone the cyl. Ebay came through for me and I got a top end set for it.
Thanks for the help!
stihltech
11-07-2004 15:20:23
Yes, if the cylinder is not gouged into the chrome, I use a small engine hone ( the spring loaded kind with three stones). If it lean seized, the aluminum from the piston deposited on the cylinder. Get that off and the cylinder will most likely be good to go.
There are aftermarket pistons out there, a lot of small engine suppliers now sell them.
If the cylinder is gouged into the chrome, replace the cylinder. No oversize pistons.
jokers
11-07-2004 15:31:49
 Re: Stihl 026 in reply to stihltech, 11-07-2004 15:20:23
Just be darned careful that you don`t catch one of the stones in a port, you can do significant damage to the cylinder. A better method of honing a piston ported engine cylinder is to use a ball hone that is approximately 10% smaller diameter than the bore.
I`ve tried honing with both types of hones, not honing at all, and scuffing the bore with a Scotchbrite, all with equally satisfying results.
You can also buy high quality aftermarket top end kits which include a new cylinder, piston and rings, or just a piston or rings from Jeff Sikkema at S&S Sawshop for significantly less than Stihl`s OEM prices. I`d also recommend that you always replace the wrist pin bearing and clips and pay attention to the orientation of the clips before you pull them so that they go back in properly.
Try this link for S&S:
jokers
11-07-2004 15:37:48
 Re: Stihl 026 in reply to jokers, 11-07-2004 15:31:49
Umm..... can`t post a link. Try snssawshopdotcom
