Tool Talk Discussion Forum
refrigerator in cold shop
SteveB
11-05-2004 04:46:36
I was wondering if my beer will freeze in my unheated shop refrig? The temp gets down to 0 a few days a winter.
JoeMN
11-05-2004 20:06:42
 Re: refrigerator in cold shop in reply to SteveB, 11-05-2004 04:46:36
Perhaps President Bush could shed some light on this weighty matter. He spent forty years studying this subject and I would defer to his expertise.
kjm
11-05-2004 18:46:31
Steve, The cure is a SMALL light bulb (25 watt works fine in north Mo) in the bottem of the fridg. the xtra heat will keep it from freezing but not hot enough to ruin the beer. At least it works in Pepsie and Coke machines here.(Some coolers have light bulb sockets in them) kjm
Redmud
11-05-2004 18:26:40
Steve, The problems I had with beer in the shop, was keeping it in the frig. You will have lots of buddys if they know you have beer in the shop.
Redmud:
Scott Green
11-05-2004 17:47:17
Years ago , we use to keep beer in a fridge , in the shed. Never had it freeze in NY winters.
Hal/WA
11-05-2004 16:08:36
Yes, it probably will freeze if it is cold enough long enough. However the problem I have had with my refrigerator/freezer in my attached garage is that it doesn't cycle often enough to keep frozen food frozen in the freezer section.
In winter, my garage usually stays somewhat above freezing most of the time, but unless I turn on the electric heaters, the only heat it gets is from the car and what leaks out of the house. I think that conventional refigerator/freezers are designed to operate at normal room temperature--around 70 degrees F.
I like the idea of constantly adding a little heat to the inside of the refrigerator with a light bulb. That should take care of the potential problem of beverages freezing in the refrigerator compartment and also the problem of the freezer compartment not being cold enough because the system never cycles.
I will try it. Last year I lost several half gallons of ice cream that melted and made an ugly mess. Thanks!
Eye N Stein
11-05-2004 19:33:20
 Re: refrigerator in cold shop in reply to Hal/WA, 11-05-2004 16:08:36
There is a much simpler solution to your dilemma. Turn your refrigerator upside down,the cold air sinks displacing warmer air to your refrigerator thermostat,causing the refrigerator to cycle,freezing what should be frozen. Remember to turn over the beer cans before opening so they are right side up.
haulnredneck
11-05-2004 16:06:54
frigidaire appliance company makes a thermostat for refrigerators that will be used in shops. the retro kit isnt very expensive. and you can drink your own beer.
Ryan
11-05-2004 14:59:02
Memories...memories....I used to have the same problem, had to keep my beer in the fridge so it would freeze up. My trouble was I would open a beer and set it down when working on a tractor and the next thing I knew it had ice crystals in it. Don't know what beer your drinkin, but a little more alcohol content might help you out too.....
Ryan
farmermatt
11-05-2004 08:25:12
Weve solved that problem by disabling( making it on all the time) the light switch that comes on when you open the door. Put a higher watt bulb (like 60) in the fridge. Ya it burns a little power but not much. When the weather warms, unscrew the bulb. Its kind of a crude fix but it works.
txblu
11-05-2004 09:31:30
 Re: refrigerator in cold shop in reply to farmermatt, 11-05-2004 08:25:12
That's what I meant when I said use a large bulb. Doesn't take much wattage in that confined space (specially iffin it's full of beer)to keep the status quo.....unless it really gets cold and stays that way. But if it's that cold, I think a hot cup of green tea would do better.....and yeah you can put a bit of snort in it iffin you have to.
Think the Brits have the right idea. Get out the BRANDY and warm the belly.
Mark
john in la
11-05-2004 07:39:41
 The Solution in reply to SteveB, 11-05-2004 04:46:36
The solution is to watch the weather man and on those nights that it will get to cold and freeze the beer is to call every one you know for a free for all before it goes bad afternoon.
Joe (Wa)
11-05-2004 07:47:46
 Re: The Solution in reply to john in la, 11-05-2004 07:39:41
I agree with John, don't leave any beer in the fridge overnight. And don't pester your friends to help drink it up, difficult as it may be you can handle it by yerself with some practice.
Joe
txblu
11-05-2004 09:28:20
 Re: The Solution in reply to Joe (Wa), 11-05-2004 07:47:46
I like associating with smart people that know how to solve complex problems.
First cold snap ya'll come over and let's empty my frig. Grin.
Mark
Dug
11-06-2004 16:00:34
 Re: The Solution in reply to txblu, 11-05-2004 09:28:20
Mark,
I'm thinkin' we oughta have a coupla practice runs before the cold weather hits. Load up the fridge we're on our way!
Dug
txblu
11-08-2004 11:51:01
 Re: The Solution in reply to Dug, 11-06-2004 16:00:34
Common. Just head south till ya smell it and west till your boots start feelin gooey. Yer there.
Mark
Kendall
11-05-2004 07:01:30
Maybe, maybe not but most likley yes, if it stays too cold too long. The thermostat in the fridge will try to keep it at 40 degrees (if thats what its set at). Once the outside air falls below 40 degrees, the inside will never heat up so the thermostat thinks all is well and never turns on the compressor. The colder it gets outside, the colder it gets inside. What if you never turned on the heater in your house. You know it gets colder and colder inside. Same with fridge. Just check on it when the temp falls below freezing.
txblu
11-05-2004 05:58:56
Yes.
Insulation merely slows the rate of thermal transfer; either direction. So if the outside temp stays below the temp that beer freezes for a couple of days, it's frozen. Since beer is only 5% alki, mostly water, it pretty much follows the 32F thing.
Take it in the house on those cold days. Besides, since you are probably in there too, on those cold days, it's closer to you soas you can get to it easier.
Mark
Mattlt
11-05-2004 04:57:57
Nope. Provided the frig is working properly. It will actually "heat" the contents when the outside air temp is below freezing.
I'm sure T-bone can supply the technical answer as to how this works.
Think of a pop machine that sits outside.
Leland
11-05-2004 21:50:19
 Re: refrigerator in cold shop in reply to Mattlt, 11-05-2004 04:57:57
Matt you are wrong I used to fill soda machines and it will freeze and bust and make a nasty mess to clean up.
thurlow
11-05-2004 07:07:21
Don't know about beer, don't have any technical answers, but..... ....soft drinks freeze in mine every winter, if I forget to take them out.
txblu
11-05-2004 06:07:23
Don't know what kinda cooler you're talking about unless it's a heat pump.
The ref unit (compressor) is controlled by a thermostat. Iffin the temp (where the thermostat sensor bulb is located) is below the thermostat set point she ain't gonna close and the refer ain't gonna come on. Then it's a matter of what is the delta t, what is the R factor of the walls of the ref, and how long will it take for the two to equalize..... i.e. freeze your beer.
Iffin you're going to heat the inside you have to provide a heat source. Now that could be a large light bulb, or you could have your beer hot and survive for a couple of days while it's cooling down to the environmental temp, but no heat source, and in time, the innards and outtards become one in the same temp. Iffin the outtards is going up and down, like cold nights and mild days, it's a game of tag. The inside tries to follow the outside but how fast it can follow it is determined by the R factor of the frig insul. Higher the R, slower it responds.
Pure physics my man.
Mark
T_Bone
11-05-2004 10:45:47
 Re: refrigerator in cold shop in reply to txblu, 11-05-2004 06:07:23
Hi Matt & Mark,
Matt would be correct in that the cold product will heat the colder ambient air and transfer heat up to the point of time the product has no more BTU's to give up.
Then Mark would be correct as the unit will not come on as the cold control (thermostat) will not let the unit come on below it's cut-in set point and the "big freeze" is on removing additional BTU until the product becomes solid.
We have to add 450btu/lb to our calculations at the temperature stall point to lower/raise the product temperature. The stall point being the temperature at which a liquid begins to turn solid or a solid becomes a liquid.
Most home refrigerator cabinets full of product loose/gain heat at 10� per the first 24hrs then 20� the second 24hrs. Most of the heat leakage is at the door gasket.
Commerical refrigeration cabinets are slightly better.
This would be with the cabinet in the shade. Sun temperature is typicaly 10� warmer than shade ambient temps.
Most unheated buildings are 10� warmer inside than the outside ambient temps with zero air flow other than natural covection air currents.
In talking refrigeration, we only have a absence of heat, as "cold" only ocurrs at minus 460�.
txblu
11-06-2004 05:49:00
 Re: refrigerator in cold shop in reply to T_Bone, 11-05-2004 10:45:47
Nice thread T. My "beer" cooler has the bad door gasket syndrome for sure. Bout time to replace the gasket and the rest of it too. Bout 20 yrs old. Maybe if my buddies on here help me rid it of it's contents before it freezes, it will be easier to move. Grin
Later,
Mark
DaveCA
11-05-2004 17:46:10
Nice facts Mr Bone sir :p
I don't have time to read this whole thread now.
I heard that some frig's have heating elements inbetween the two walls leading to the outside to dry it or something. True?
If so it would be better to leave it plugged in I suppose.
T_Bone
11-06-2004 15:34:54
 Re: refrigerator in cold shop in reply to DaveCA, 11-05-2004 17:46:10
Hi Dave,
There is a special name for that heater, I just can't remember it. What it does is face the door gasket and keep the gasket surface slightly warm. This keeps ice and condensastion from building on the face so the door gasket will seal.
Door gaskets have a magnet inside the gasket and that is what makes them seal "if" the door is in close alignment.
T_Bone
Joe (Wa)
11-06-2004 21:43:43
 Re: refrigerator in cold shop in reply to T_Bone, 11-06-2004 15:34:54
Here is a hint T_bone...mullion heater...you're going to have to come up with the correct spelling tho.....
Joe
DaveCAl
11-07-2004 07:12:00
 Re: refrigerator in cold shop in reply to Joe (Wa), 11-06-2004 21:43:43
Did a search and found this.
Thanks for responses T_Bone and Joe (WA)
DaveCA
I forgot my password
txblu
11-06-2004 05:46:43
You may be talking about a defroster that comes on sometimes in the night to melt the frost off, i.e. "automatic defrost".
Mark
Coloken
11-05-2004 07:32:12
I go with Mark 100 percent. Had pop (soda to You eastern guys) machines. Just like a good insulated box. they will hold for most cold spells but I lost some when it was like 0 for several days. I think the large quanity of liquid helps to hold from freezing. The soda pop companies in Colo. leave them out so go from that.
Leland
11-05-2004 21:54:09
 Re: refrigerator in cold shop in reply to Coloken, 11-05-2004 07:32:12
Soda will not freeze solid until about 15 degrees bacause of carbnation,any thing lower than thak we had to park trucks inside at night.
Farmered
11-06-2004 02:32:07
 Re: refrigerator in cold shop in reply to Leland , 11-05-2004 21:54:09
It ain't the carbination Leland. Diet drinks will freeze at 32 F. Regular sodas (pop) will go a little colder before freezing. It's the sugar.
Former CocaCola distributer in a Northern state. Ed
Leland
11-06-2004 15:31:11
 Re: refrigerator in cold shop in reply to Farmered, 11-06-2004 02:32:07
Well that whats coke told us,former vending route service man had 75 soda machines + snacks machines to service.
txblu
11-05-2004 09:20:36
Thanks Ken. And yes, the heat (removal flux rate) is also dependent upon the mass to be cooled. Bigger the mass, for a given delta temp and R factor, longer it takes to get to the freezing temp.
Mark
john in la
11-05-2004 07:45:32
"Had pop (soda to You eastern guys)"
What is POP or Soda ????? ????? ??
Is that DAD and Soda water.
OH!!!!! !! You mean COKE. (to us southern boys)
Does not matter if it is cola or root beer or strawberry it is all called COKE in the south.
leland
11-06-2004 16:01:06
 Re: refrigerator in cold shop in reply to john in la, 11-05-2004 07:45:32
And whats this crap down south ya all what slaw on that boogger
thurlow
11-05-2004 07:49:48
Mid-south..... .Coke or co-coler
txblu
11-05-2004 09:25:48
 Re: refrigerator in cold shop in reply to thurlow, 11-05-2004 07:49:48
Now see, that's how companies loose their BRAND NAMES which are patentable. Using the (descriptive) adjective as a noun (Coke brand name) when you are talking about a cola, eventually becomes the accepted name and the patent goes phooey.
My old company had a problem with that and chewed us royally. We had a "snap action thermal switch" (like a click-click frog clicker...Vietnam pager) that we referred to by the company patented adjective (trade name) KLIXON. Next thing you know the switch was a klixon not the other and bye bye patent.
But in my part if Texas it's just "gimme a beer". Grin.
Mark
